Red Engine Paint- 85 308-GTS | FerrariChat
Discussion in '308/328' started by 308GTS-85, Nov 21, 2019.
  1. 308GTS-85
    308GTS-85 Rookie
    Nov 5, 2019
    12
    SoCal
    @brinkerscuderia
    Hello... Looking to see if anyone has done a repaint on the top of the Motor? My red paint has come off in some spots ( was this way when I purchased) and I'm looking to redo it.
    Wanted to get a close match.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Do you mean the valve covers or plenum...or the actual block?
  3. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    402
    PA
    Alex
    Refinished my plenum over two years ago using VHT High Temperature Wrinkle Plus Coating (SP204). I bought two 11-oz cans from Amazon. This was based on recommendations found on FChat. All the procedures are posted (I went with chemical stripping). As you will read, it does a nice, durable job but is slightly less red and slightly less wrinkly than factory. My eyes/brain may be playing tricks on me but it seems to have gotten to a deeper red (closer match) after many heat cycles. There may be better paint choices available today.
  4. 308GTS-85
    308GTS-85 Rookie
    Nov 5, 2019
    12
    SoCal
    @brinkerscuderia
    Thanks Alex... Much appreciated!
  5. Rifledriver
    36,769
    For OTC products that is about as good as it gets. The original color changes for all sorts of reasons so matching to what is there can be a real challenge. The amount of wrinkle can be modulated by application technique but from the factory it was very inconsistent so there is no "Correct". If powder coat is preferred one of the large suppliers has a product called Desert Red that is good to.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,398
    San Carlos, CA
    Mitchell Le
    If you bake your VHT red wrinkle paint after three layers applied, it will be tightly wrinkled but less shiny. I have a $25 over in the outdoor shed I use for that purpose. The kitchen oven and dishwasher are off limit to my automotive activities.
    ferrariowner likes this.
  7. yelcab
    Nov 29, 2001
    13,398
    San Carlos, CA
    Mitchell Le
    BTW, after you apply VHT paint and get the wrinkle you want, you can apply a layer of Rosso Corsa over the top for correct color. I thought that was overly complex so I never did. I just wait for the VHT color to darken over time and heat cycle. It gets close.
  8. 308GTS-85
    308GTS-85 Rookie
    Nov 5, 2019
    12
    SoCal
    @brinkerscuderia
    Appreciate the info!
  9. 308GTS-85
    308GTS-85 Rookie
    Nov 5, 2019
    12
    SoCal
    @brinkerscuderia
    It's the plenum.
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,766
    Cerritos, CA.
    Personally, I prefer powder coating it, it’s more durable and last way longer.
    BOKE, Rifledriver and thorn like this.
  11. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I've had the valve and cam covers powder coated by a local company, and at some point I'll have the plenum done as well. So far I've been thrilled with the results.
    miketuason likes this.
  12. miketuason
    Feb 24, 2006
    15,766
    Cerritos, CA.
    308GTS-85, djs308, Jbrauer and 2 others like this.
  13. Rifledriver
    36,769
    Thats like saying if they knew the coating would get sticky they wouldn't have used it on all those interior pieces.
    They have the choice now and they still are not using powder coat and they are still using sticky coatings.
    Face it, the company is run by the bean counters.
  14. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,597
    California SF bay area
    Paul
    I took my plenum to Ned's AutoBody and had them make me up a two part rattle can in matching color but it wasn't wrinkle finish so they told me to spray it with VHT wrinkle first and then spray the final color over it. I tried but the final coat just washed out the wrinkles (or filled them in) So I just redid it with the VHT red and while it isn't as dark a shade as the original I ended up not sweating about it so much and am happy with the results.
    It's possible that I just didn't give the wrinkle base enough cure time and doing plan A would have worked if I had had more patience.
  15. Jonny Law
    Jonny Law F1 Rookie
    3,199
    Over yonder.
    IT Guy
    My biggest concern would be calcium or other particulates from the water filling the crevices of the crinkle.
  16. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,597
    Paul
    What water?
    Rifledriver likes this.
  17. Dr Tommy Cosgrove
    36,242
    Birmingham, AL
    Tommy
    I did mine that way probably 20 years ago.
  18. Banzairacer
    Banzairacer Formula Junior
    486
    San Diego, CA
    Sanjeev Thohan
    Hi mike where did you get the plenum intake hose - carbon fiber?
    jrinehart likes this.
  19. miketuason
    Feb 24, 2006
    15,766
    Cerritos, CA.
  20. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,153
    CT
    John Kreskovsky
  21. Arvid
    Arvid Formula Junior
    May 28, 2012
    668
    Norway
    Arvid Andersson
    I just ordered from here : www.kcolors.com. They supply wrinkle paint for Ferrari and Lamborghini. Can be ordered in either spray cans or liquid cans.
    I tried the red VHT but it's to pinkish red - does not look good at all.
  22. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,117
    Mansfield, TX
    Ron
    I found the VHT rattle can to work pretty well. It appears to be a slightly different color (red) than original. The original color on my plenum was slightly more orange compared to the VHT.
  23. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Sounds like if you lined up 5 OEM cars, you would have 5 slightly different paints tones and finishes. Just saying.....
  24. Rifledriver
    36,769
    Exactly correct.
    waymar likes this.
