Red Hot Cat Help!! Please | FerrariChat
Discussion in '360/430' started by george111, Feb 12, 2012.
  1. george111
    george111 Karting
    Aug 21, 2011
    120
    florida
    360 CS
    After a recent short drive I received a Slow Down LIght with an intermittent brief CEL..
    I drove home slowly and let the engine cool down..After about an hour I check the cats and manifold temp..left side both very cool....Right side still burning hot for the cat and the manifold is also hot..
    can this be a bad cat or is it more likely an engine or ignition problem? Engine seems to run well..
    Any info deeply appriciated..
  2. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    Any maintenance work was done to the car recently? Any code(s) that you could read from the car?
  3. arizonaitalian
    arizonaitalian Two Time F1 World Champ Owner Silver Subscribed
    Oct 29, 2010
    20,507
    Wyoming
    When the exhaust overheats, it will do that. Happened to me once when it was 100+ outside and then it was fine after cooling down. Goes into "limp" mode which makes it hard to get home!
    I had the local f-car dealer check it and they said that was what it was (after looking at the codes) and not to worry.
    Now, why your event happened after a short drive in (I'm assuming) fair weather? No idea...it was freakin' hot when I had this happen (but mine was also after a very short drive that day). So...I think it could be something else...time for a check up.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Or maybe not as the two new threads suggest you do not accept the first reply to your original thread ?
  5. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,528
    Charleston, SC
    Curt
    my bets would be on a bad coil (s). may not be apparent with Leonardo..
  6. doug_porsche
    doug_porsche Karting
    Dec 6, 2009
    147
    Trying 2 find myself
    Doug
    I had two different cats that caused blockage.
    No power, exhaust was red hot (literately).
    Yep, i could be a bad cat
  7. TAFORZA
    TAFORZA Formula Junior
    Jun 5, 2008
    296
    San Francisco, USA
    Tony A.
