Red 'paste' on electrical connections? | FerrariChat
Discussion in 'Technical Q&A' started by Andy 308GTB, Jan 13, 2013.
  1. Andy 308GTB
    Andy 308GTB F1 Rookie
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    #1 Andy 308GTB, Jan 13, 2013
    I'm trying to get the ignition working on my 308 and I've been forced to go far deeper that I would have wished to be honest! It uses a magnetic pulse from the Distributor to trigger the Coil.
    The amplifier/sensor that sits between the Distributor is shown in the photo.
    The terminals of the amplifier that connect to the coil have a red 'paste' smothered on the connection. Any ideas what this is and what purpose it serves?
  2. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,255
    Gold Coast, Aust.
    Patrick
    Di-electric grease
  3. DanS*
    DanS* Karting
    May 29, 2012
    218
    Manhattan Beach, CA
    Dan
    Whose purpose is maintain good electrical contact while preventing corrosion.
  4. tazandjan
    39,301
    Andy- You can buy it in a spray can and I use it on battery terminals to prevent corrosion. Works great. Without it, you would probably have a bunch of fuzzy corrosion on those contacts. Works better than Vaseline, which we used in the olden days.
  5. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    Thank you all.
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    While you have the ignition parts out of the car, it's a good idea to replace the thermal grease between the BKL 1A ignition module and the heatsink as it is most probably gone by now.
  7. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    Agreed, this is likely dielectric grease, there should be some beneath the module as well.
    That Magnetti Marelli module sure looks like a GM "HEI" knock off. Those can be had stateside for $15, makes troubleshooting easy.
  8. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    1. There is paste underneath the unit but I thought that would be heat sink paste but it did cross my mind that it could be dielectric grease. Can you confirm?
    2. Yes, I noted the GM stamp on the amplifier, the only code on the unit that could be a part number was '466'. These units are about US$ 100 each from the usual suspects. If a GM part number could be found it would save me a fortune - as I'd like to replace these too. I have searched on the interweb for GM 466 combined with amplifier/sensor etc but with no luck.
    Are you talking about the Coil or the Amplifier/Sensor (I'm guessing Amplifier/Sensor)
  9. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,751
    Berlin, Germany
    Adrian
    The paste underneath the ignition module is heat sink paste (thermal grease), it makes sure that the heat from the underside of the module is transferred to the heat sink. The paste on the terminals is silicone grease (also called dielectric grease), its job is to seal out humidity and to prevent corrosion of the terminals. Your ignition module can live without dielectric grease but not without thermal grease, at least not for very long :)
    Marelli used GM OEM modules in early AEI200 ignition units (the heatsink/module/coil unit) and then later on used their own BKL 1A modules, part number Marelli 940038521.
    Although the enclosure and terminals of the modules look identical to the standard GM units, the specifications of the different GM four terminal modules are quite different in terms of output power, current and dwell control. I've posted a list of compatible replacement modules here: http://www.ferrarichat.com/forum/showpost.php?p=140835140&postcount=20
    As example, the Hella 5DA module is around £29 in the UK, so no need to spend $100.
    The ignition module (Amplifier), which is mounted on the large heat sink.
    Best,
    Adrian
  10. Andy 308GTB
    Jun 2, 2004
    2,669
    Essex, UK
    Andy M
    Thanks again - that is extremely useful
  11. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    I'll jump in, having had a Pantera years ago and say that the substance is not dielectric grease (which is specifically intended to be not only non-conductive, but to have a high dielectric constant and provide electrical insulation for things like spark plug wire boots).
    instead, I think it is an electrically conductive paste intended to both prevent corrosion while at the same time helping make sure the connection stays sound.
    An example of the material is here:
    http://www.sanchem.com/aSpecialE.html
    I don't have any of this stuff, but it did wonders for the crappy 70's era electical connections on that car.
  12. Ferraridoc
    Jun 20, 2012
    17,255
    Gold Coast, Aust.
    Patrick
  13. bill365
    bill365 F1 Rookie
    Nov 3, 2003
    3,319
    Chicago area
    Bill
  14. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    #14 Pantdino, Jan 19, 2013
  15. DesertDawg
    DesertDawg Nine Time F1 World Champ
    94,245
    The Desert
    DesertDawg
    It's fine to smear it on the connectors... most of it will be wiped off as the connection is made, but any that remains is going to be beneficial, because a semi-conductive state is better than a tiny arc. At that stage, we're talking almost the molecular level, but still. The fact that it keeps moisture out is also a benefit that outweighs any lack of conductivity to the tiny, tiny percentage of uneven surface area that might not be making full contact.
  16. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Ross
    #16 It's Ross, Jan 21, 2013
    Heat sink paste, yes, sorry about that.
    As far as those modules go, you might want to talk with an experienced(old) GM parts guy. The 466 could be a suffix that will be meaningful.
    FWIW I'm pretty sure those modules covered a broad spectrum of vehicles and it would be hard to get one that wouldn't work.
    This popped up with a "GM HEI ignition module" search. Note the long list of applications, including Fiat.
    http://www.ebay.com/itm/GM-Chevy-Ignition-Control-Module-4-Pin-HEI-Distributor-/320635444061#vi-content
    A Wells DR100 module ought to be in stock at your local parts house
