Red Wings T204 crash in Moscow | FerrariChat
Discussion in 'Aviation Chat' started by Peloton25, Dec 30, 2012.
  1. Peloton25
    Peloton25 F1 Veteran
    Jan 24, 2004
    7,646
    California, USA
    Erik
  2. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    16,967
    Wellington, FL
    Duane
    That video is something else!
  3. tomkatf
    tomkatf F1 Rookie
    4,116
    San Diego...East Co.
    Tom F.
    Good Lord... Is that the nosewheel that broadsides the car directly in front??? It ricochets off the bottom of the overpass and hits the car in the side...
    T
  4. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,019
    Huntsville, AL., USA
    Andrew
    Saw this on BBC News - terrible stuff. :(
    Was that a 3-seater bench that the camera car ran over right towards the end?
    All the best,
    Andrew.
  5. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
    Yes. Ugh.
  6. wax
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
  7. Tcar
    Tcar F1 Rookie
    #7 Tcar, Dec 30, 2012
    5 lives lost now... out of 8...
    Tu-204 has been fairly reliable... only other overrun was a brake failure recently - no fatalities.
  8. dmaxx3500
    dmaxx3500 Formula 3
    1,027
    is it a law in russia,that every car/truck must have a dash cam?
  9. Tcar
    Tcar F1 Rookie
    Subsequently, it looks like 3 total of the Tu-204's have had 'crashes' since the introduction of the model.
    2 of the 3 were overruns (including this one). Both overruns were due to brake issues.
    Appears it was NOT PILOT ERROR in either of the overruns (including this one.)
  10. 4re Nut
    4re Nut F1 World Champ
    Mar 27, 2004
    16,343
    N of NOLA
    Steve
  11. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
  12. Peloton25
    Jan 24, 2004
    7,646
    California, USA
    Erik
    Not a pilot, but shouldn't they have tried pulling up then?
    >8^)
    ER
  13. Tcar
    Tcar F1 Rookie
    They were all out of runway before they realized (probably) that the reversers were not working.
    Assume there's an interlock preventing the brakes AND REVERSERS AND SPOILERS from working unless both main gear are loaded.
  14. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    If you look at the article it showed that is alternated from left to right main gear being compressed. Both gear switches did not switch until the A/C ran off the end of the runway.
    An earlier report advised TU-204 operators to make sure that the reverser unlock lights goes green prior to throttling up for reverse thrust.
  15. justinn
    justinn Karting
    Jan 5, 2011
    114
    Austin TX
    Justin
    Having been to Russia a few times, I can tell you that the primary reason for having the dash cams is accidents. To prove fault in the event of one. It is not mandatory, but if you ever visit Russia and experience their driving first hand you would see why cameras are so popular.
    Justin
  16. justinn
    justinn Karting
    Jan 5, 2011
    114
    Austin TX
    Justin
    I believe they knew the reversers were not working which is why they cycled them multiple times. Since they didn't have compression on the mains, the computer would not let the reversers deploy instead causing increased speed as the fans spool up. They had 32 seconds to attempt everything they could to get the plane stopped. Unfortunately, nothing worked to their advantage.
    Justin
  17. Tcar
    Tcar F1 Rookie
    #17 Tcar, Jan 25, 2013
    I did read the article... just looking for clarification.
    Going to 'idle reverse' (like LouB747 does) before hitting the throttles sounds like an excellent idea.
    Even that won't work if you don't get both mains on the ground, maybe.
  18. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Looks like Red Wings is being grounded.
    Incident: Red Wings T204 at Moscow on Jan 29th 2013, thrust reverser did not correctly open on landing
