Redline Oil | FerrariChat
Redline Oil
Discussion in '360/430' started by alex360S, Nov 5, 2009.
  1. alex360S
    alex360S Formula Junior
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Those of you using Redline oil in your 360's, have you stuck to 5W40 or are you using another formulation? I know there has been alot of talk in using lighter weighted oil but I only find it confusing and makes me feel like I should stay with the manufacturers recommendations. Btw, can someone tell me where I can get 5W40 oil in either Redline or Q -Horsepower here in Canada. I've researched around and nobody is willing to sell me 5W40. I guess someone's got a hold on the oil companies?
  2. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    First, Redline is the best oil for your 360. I recommend 0w40 because it less wear on cold start. If you can’t find the 0W, 5W is fine. Use the internet to buy it. It is easy for you because you can get it by ground because it is hard by air. Good luck.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,501
    i get mine from napa auto parts
  4. alex360S
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Just found it at Precision Tuning Motorsports in Ontario. A little pricy compared to the US (12.99/bottle) but at least they have 5W40 and are willing to sell it to me. I should have it in 2-5 days. Thanks for the feedback.
    Alex
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,774
    Redline data
    xxW-yy -- cold -- warm --HTHS
    ------------cSt----cSt----cP
    10W-30 -- 70.0 -- 10.7 -- 3.8
    00W-40 -- 81.0 -- 15.1 -- 4.0
    05W-40 -- 94.0 -- 15.1 -- 4.6
    10W-40 -- 93.0 -- 14.6 -- 4.7
    The increase in cold weather startup protection is obviated when the oil gets hotter then 212dF. Thus while 0W-40 is fine for startup protection, it is marginal at track temperatures. 10W-30 is almost as good as 0W-40 at track temperatures, and much better for startup, and perfectly adequate for normal operation.
    10W-40 is thinner at startup, thinner in normal operation, and thicker when it really counts (compared to 5W-40). Thus, 10W-40 is better for your car than 5W-40 under pretty much any conceivable set of circumstances.
  6. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Great Feedback! Very helpfull.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,850
    Cerritos, CA.
