Redneck Homelink for 360/430 | FerrariChat
Discussion in '360/430' started by Bob in Texas, Jun 13, 2016.
  1. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,734
    Just East of Weird
    Bob
    #1 Bob in Texas, Jun 13, 2016
    I live in a gated community and the gate opener always seems to hide beyond my reach in the nether regions of the glove box when I need it. So i decided to do a mod that was kinda popular to porsche 996/986's.
    For about half an hours work i did a jury-rigged gate-opener that is activated using one of the OEM 360/430 switches. It works for garage door openers too. (the original porsche thing)
    I soldered 2 wires to the bottom of the gate opener switch on the circuit board. They are kinda obvious and I used an ohm meter to see that they were the correct solder joints. I used an OEM switch i bought off of eBay and identified the 2 pins that activate the red light on the opener. The switch is mounted in the 4th "blank" spot to the left of the steering wheel. The opener is velcro'd under the dash. Now all i have to do is hit the switch and abracadabra, the gate opens.
    Works like a charm...
    yes, yes, i could just put the opener in one of the console trays, but I don't...
    whatheheck and Raconteur like this.
  2. ncm6cabrio
    ncm6cabrio Formula Junior
    Jul 28, 2011
    303
    Fayetteville, NC
    Mike M.
    Nice- I like it!
  3. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    That's cool! I need a 2 way toggle switch. Go up for the gate and down for the garage. Is that doable?
  4. F1Spider
    F1Spider Karting
    Jan 8, 2013
    199
    Austin
    Stuart
    Bob,
    Luv ya man! Clearly a bad azz functional garage door opener and from a dash perspective you made it look OEM. I need this for my 360, but unfortunately I am not mechanically inclined.
  5. dreichman
    dreichman Formula Junior
    Sep 9, 2011
    425
    Denver, CO
    Simple and creative. Always the best solution. Bravo! 👍🏻
  6. Cinque
    Cinque Formula Junior
    Aug 4, 2012
    402
    West Coast
    Impressive skills, you must be an engineer!
  7. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    #7 kommons, Jun 14, 2016
    @sandy - It's doable. Use one of the Stradale Window switches then use a homelink visor unit that's programmable.
    I had same idea as OP some time back (great minds??, amirite) I used a glove box switch, then flipped the logo so it looks like a garage door. I also run illumination wire so it lights up at night.
    I also re-ordered the buttons in a way the made more sense from a usability standpoint.
  8. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    Very cool 👍
  9. Bob in Texas
    Apr 23, 2012
    2,734
    Just East of Weird
    Bob
    Great job Chris! Where did you mount the homelink?
  10. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Like this hack! Great job on the OEM look!
    Chris, where did you tap into the illumination wire? Also, did you your door opener like OP or did you use a home link and hardwire powe?
  11. Sandy Eggo
    3,636
    Encinitas, CA
    Rick
    Awesome!
  12. tazandjan
    39,189
    #12 tazandjan, Jun 14, 2016
    Very ingenious. This is what I did for mine. Homelink unit is incorporated into the dome light assembly. Spare dome light assembly, so easily reversible. LED to tell you it is working.
  13. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    There's an empty connector in my car (I think its for rear fog) I used a blade terminal to connect to the other buttons illumination pin. I try to do all of my mods in a way that they are 100% reversible without damage. If I had all buttons used, it may be more difficult. You could use a T-Tap or pull the pin out and solder a small wire to it.
    I bought a homelink visor from a Kia for 15 dollars then gutted the board and installed it right under/behind the AC vent.
  14. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,226
    Shorewood, MN
    Kevin
    How does one go about flipping the logo on one of these switches? Is it simply a matter of removing and replacing the decal?
    Kevin
  15. tazandjan
    39,189
    Send it to one of the sticky refinishers and they can remove the old logo and put whatever you want there or leave it blank.
    kes7u likes this.
  16. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    Yes, It's a piece of translucent plastic, anchored to the sides. you have to be careful with the buttons, they are a bit fragile (also have small springs inside if you decide to open them fully), but its doable.
