REFILLING engine cooling/heating sys. 3500GT Vig. Spy. PROCEDURE??? | FerrariChat
Discussion in 'Maserati' started by Arakis36, Oct 21, 2010.
  1. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Hi All,
    - I emptied all my anti-freeze from my 3500GT Vig. Spy., radiator and complete heating system...
    Is there a specific procedure of Refilling to respect?? If so, how do you go about ??
    - Also what are the 2 faucets found in the cooling/heating system ?? One is found on the right side, rear of engine block valve cover and the other left front, bottom of engine block (by the wishbone suspension) ??
    Many Thanks to ALL
    Ciao
    Carlo
  2. thecarnut
    thecarnut F1 Rookie Rossa Subscribed
    Apr 22, 2006
    3,237
    Atlanta
    The Car Nut
    The "faucets" you are referring to are most likely the manual heater shut of valves. These tend to go bad therefore it is a good idea to make sure they work in the open and closed position. Take a look at ebay item 350399111549. These valves are available from several sources.
    No special procedure for filling the radiator. Turn on manual heater valve(s), turn on heater, fill the system with 50% distilled water and 50% coolant.
    Ivan
  3. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Thanks Ivan,
    Luckily my heater shut off valves do work, as I took'em apart, cleaned them and tested them... I understand their use, I simply wonder what is the purpose of manually shutting off the heater system....
    Cheers
    Charles
