Refinish Cam Covers 348 | FerrariChat
Discussion in '348/355' started by rolaszek, Feb 24, 2016.
  1. rolaszek
    rolaszek Karting
    Apr 28, 2010
    57
    Plainfield, Ill
    Bob the nubie
    Have correct paint to refinish cam covers on 348. Would like to solicit advice
    as to best sealant to use when replacing covers on new gaskets.
    Thanks in advance.
  2. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    No sealant to use on the cam cover gaskets however I did provide a small smear of sealant around the vulnerable oil seals, but only on the bottom edge.
    If its just the covers and your not removing the cams / oil seals, I wouldn't use any.
    I used Bentley CAF1 but Im sure you have alternatives over there.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Hondabond.
  4. plugzit
    plugzit F1 Veteran
    7,776
    Redondo Beach, CA
    Bruce Bogart
    Hondabond
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Hondabond, or Supergrey Permatex
  6. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    Out of curiosity, what is the correct paint? The wrinkle pattern is so specific on the covers with those little squiggly lines running everywhere...
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Hondabond HT
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    There is a wrinkle powder coat that looks great on the cam covers and lasts longer than most paints. Sorry, but I don't know the manufacturer or part number, but a powder coater familiar with Ferraris should be able to help you.
  9. LorenzoR
    LorenzoR F1 Rookie
    Maybe u can use black wrinkle paint then spray the red over it
  10. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    The VHT red wrinkle looks great.
  11. yelcab
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    You can't get the right Ferrari red but the VHT one comes close enough after six months.
  12. LorenzoR
    LorenzoR F1 Rookie
    Are the cam covers Rosso Corsa?
  13. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I think it's a little more orangish in it the rosso corsa?
  14. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    I'm an engineer, and there's a lot of times where I need info on something that I can't find online. I've found a lot of times just randomly phoning a manufacturer in the industry eventually connects you with a person who will answer your question. I feel like this is one of those things where if you called the right people at Ferrari and asked politely eventually someone would forward your question to the right person and they would tell you the correct paint. Maybe I should try and see what happens.....
  15. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    <popcorn>
  16. m.stojanovic
    m.stojanovic F1 Rookie
    3,227
    Serbia - Niš
    Miroljub Stojanovic
    #16 m.stojanovic, Feb 27, 2016
  17. m.stojanovic
    3,227
    Serbia - Niš
    Miroljub Stojanovic
    #17 m.stojanovic, Feb 27, 2016
  18. LorenzoR
    LorenzoR F1 Rookie
    Looks pretty good
  19. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Love seeing refinished cam covers on the 348. :)
  20. LorenzoR
    LorenzoR F1 Rookie
    question is what paint do we use here that's readily available in the states. The paint he bought is from greece
  21. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I'm quite sure that I wouldn't be able to identify slight differences in color, even if the two cars were sitting side-by-side. So as long as it's not pink or maroon, I agree, although I'd like to get as close as possible for originality's sake.
    Your cam covers look fantastic! They really dress up the engine compartment. Great work!
  22. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    Your car is now worthless , please provide the vin number so it can be blacklisted .;-)
  23. m.stojanovic
    3,227
    Serbia - Niš
    Miroljub Stojanovic
    #23 m.stojanovic, Feb 27, 2016
  24. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
  25. R&D
    R&D Karting
    Mar 16, 2015
    168
    Kris
    #25 R&D, Mar 1, 2016
    Here's something interesting. I was in a shop at work today and noticed that this old Kennedy toolbox had almost the exact correct finish on it to match the OEM 348 valve covers. The color was perhaps a little too "tomoto-ey" red but the wrinkle pattern was almost spot on.
