348 - Refinish Defrost Vents | FerrariChat
348 Refinish Defrost Vents
Discussion in '348/355' started by QSA, Oct 20, 2019.
  1. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Completed the refinishing of my defroster vents and reinstalled today. For those that want to do this, here are some I learned and the products I used.
    - Since the parts are aluminum, I used aircraft remover to strip the coating. I would advise removing the soft-touch / sticky coating as much as you can using 99% isopropyl alcohol first, as it prevents the stripper getting to the coatings and primer underneath. I ended up using the aircraft remover, then alcohol, then another coat of remover.
    - a wire brush worked well on the screen.
    - a 400 grit sanding sponge/block worked well on the frame with all its contours.
    - I used Duplicolor self-etching primer made for aluminum, followed by Duplicolor acrylic lacquer. Sanded the primer before applying the lacquer.
    - many rounds of cleaning with alcohol till the rag had zero residue.
    - used a dremel with a wire brush to get in the books and crannies, and also helped a lot with the mesh / screen.
    - Buy a mini ratchet; it’s $7 well-spent, and will save a few cuss words for later use.
    Pics below:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    308 GTB, Wade, Challenge and 2 others like this.
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Wade likes this.
  3. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Thanks. I should add that if I had to do it again, I would buy a cheap blaster and hit it with soda.
  4. Ferrarium
    5,631
    Central NJ
    Eric
    Btw I would sent it to power coater and let them blast and coat. I did that with door sills and muffler mounts and door handles etc.
    Sent using FerrariChat.com mobile app
  5. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Sure, but that would defeat the rewarding experience of saving a buck, doing it myself, and sharing it all here!
  6. Ferrarium
    5,631
    Central NJ
    Eric
    Ohh, I can relate... just putting it out there for others who have less tolerance for diy. :)
  7. itsablurr
    itsablurr Formula 3
    Dec 9, 2005
    1,010
    Carlisle, MA
    Matt
    ...or, "Honey, we need a media blasting cabinet".
  8. A348W
    A348W Formula 3
    Jun 28, 2017
    1,748
    North Wiltshire, UK
    I took the easy way out and had them
    Powder coated satin black. Cost me about £20!
    The mesh I sprayed satin black with a rattle can!
    good work though!!
  9. Ferrarium
    5,631
    Central NJ
    Eric
    Yesssss...... yes..... WE need one, I could refinish your chairs and picture frames! lol
  10. GTO Joe
    GTO Joe Formula Junior
    989
    Charlotte, NC
    Joseph Troutwine
    Wow, I thought I was the only one to use that logic on the wife. :)
  11. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    308 GTB likes this.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  13. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    Looks new!
  14. 308 GTB
    308 GTB F1 World Champ
    11,183
    New Jersey
    Barry Wolinsky
  15. Ga68_
    Ga68_ Karting
    Jul 16, 2017
    71
    France
    Gaetan
    Barry , j'ai quelques aides sur mon site si jamais
  16. Dino L
    Dino L Rookie
    Oct 29, 2018
    35
    sacramento, ca
    William D Lozano
    Great work and you motivate me to do the same as winter is approaching. Mine look just like your before pictures.
