Refuses to start, where to start? | Page 2 | FerrariChat
Discussion in '308/328' started by qedqeq, Jun 3, 2018.
  1. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,310
    Ferrariparts.co.uk are listing 119052/A as the current alternative to the original part numbers.
    Unlucky that its the TDC - that one is a bear to get to I think
  2. qedqeq
    qedqeq Formula Junior
    Apr 15, 2015
    384
    I think that you are right about the location looks like it is buried underneath this rad hose and oil filter? Anything else I need to remove to get to it
  3. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    I accessed my TDC sensor from below. Car was on a lift which made it easier as I could stand underneath and extend my arm up to the correct location to reach the fasteners.
    Sent from my SM-G900V using FerrariChat.com mobile app
    miketuason likes this.
  4. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    The Tacho and TDC sensors are same for an 88.5 328 and I guess for yours as well. Part numbers are different but I received from Eurospares 2 of the very same with part number 119052. Originally the part number of the TDC is 128364. To make the 119052 fit i needed to increase the 2 holes in the mounting plate to a sleeve, see picture. Its a kind of difficult to get to the TDc sensor but with patience you will work it out.
  5. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    in above picture the nuts are removed...
  6. L8Again
    L8Again Rookie
    Hi.
    Lots of great info in this thread from knowledgeable people.
    Did replacing the TDC sensor solve your no-start issue, qedqeq?
  7. Tarek307
    Tarek307 Formula 3
    1,348
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Wow, so people helped the OP out with all this information and details then he doesn't even give a darn to update the thread with the solution..what a great "contributor" gotta love those kinds of guys...
  8. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,313
    Montana
    Kim
    Sounds like he’s had a rough year. Seems to be a very nice guy.
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,199
    CT
    John Kreskovsky
    Well, since he seemed to identify the problem and hasn't posted in 4 months, you can probably assume it did.
    And your contribution to the thread is?
    Welcome to Ferrarichat. I notice you are both new members. If you expect every "problem" thread to end with a "solution" you are going to be very disappointed. :(
    root, pizzadude and thorn like this.
  10. L8Again
    L8Again Rookie
    Absolutely no criticism was intended (nor I think implied in my wording - unlike the other poster). Even when things are going well, life is crazy busy and sometimes, hopefully not, unfortunate things happen to people or family. I’ve had the latter in spades, the last couple of years. Given all the other things possibly going on in people’s lives, circling back to a car forum often ranks way down the list of priorities.
    I was just hoping to learn a bit more about this technical issue.
    Regards to all.
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,467
    San Carlos, CA
    Mitchell Le
    He did say that the TDC sensor returned bad value when tested, which was the prevalent diagnosis on the thread. Peace, life goes on.
  12. qedqeq
    Apr 15, 2015
    384
    #37 qedqeq, Nov 7, 2018
    Hello All,
    Thanks for all your guys help on this issue,
    I had thought that I had responded to this post, but it was actually in the for sale post that I put up that I responded that it did fix my situation.
    Next time, I will make sure that respond in a timely manner the correct post.
    Regards
