Regitar alternator parts...holding up? | FerrariChat
Discussion in '348/355' started by f355spider, Oct 27, 2011.
  1. f355spider
    f355spider F1 World Champ
    18,047
    #1 f355spider, Oct 27, 2011
    Some feedback from my experience: Today, my Regitar voltage regulator failed, after 3.5 years and 8k miles. Aeroengineman had a Regitar VR fail out of the box. I am not impressed with the quality of these parts. I reinstalled the original Nippondenso voltage regulator (with 50k miles of use) and the light went back out, and car is running normally.
    How are they working for the rest of you?
  2. F355Bob
    F355Bob Formula 3
    Mine failed out of the box also and went back to the stock parts and so far no problem.
  3. JSBMD
    JSBMD Formula Junior
    Mar 17, 2007
    450
    The OC
    Does Nippondenso sell parts, or do they only manufacture/sell whole alternators?
    I have rebuilt twice with Regitar parts, at about 7-8k mile marks. Thought it was heat-related from unshielded headers....
  4. f355spider
    18,047
    BTW, the point of my post, is the "Alternator rebuild thread" for Nippondenso alternators lead us to believe the Regitar parts were superior to oem. I now believe that is not the case.
  5. f355spider
    18,047
  6. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    Interesting, I have a regitar reg. sitting here ( I assume that most people want the little bump in volts it provides) - I am however reluctant to install it since the ND reg. is probably the most reliable unit I have ever experienced in any car - 20+ year old hondas are still running on the original ND alternators with 300K of daily driving...
  7. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
  8. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    #8 saw1998, Oct 28, 2011
  9. f355spider
    18,047
    Scott, no I have oem shielded exhaust manifolds (rebuilt by QV London). I have had no previous problems with my alternator, and did the "upgrade" as it seemed a good idea at the time.
  10. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Thanks, Dave. Sorry for my memory lapse and thanks again for the information.
    This kinda' sucks doesn't it? :( But at least it gives an option for those with a Nippondenso alternator.
  11. f355spider
    18,047
    Okay, in Ernies thread he recommends the use of the USI regulator:
    Here is the USI part number:
    regulator - #00632, 71-30003/SCP
  12. f355spider
    18,047
    #12 f355spider, Oct 31, 2011
    I cannot confirm the veracity of this post, so use with caution, but found this list of cross references for the USI and Regitar voltage regulators:
    ACE
    VR-1243
    ACE TRI-STAR
    VR1243
    AIM
    AT-10136, AT-1049
    AMSCO
    ND-449, TY-560, TY-560T
    ARROWHEAD
    AND6003
    BARSANCO
    216-013
    BOSTON AUTO
    38090-4378
    CARGO
    131459
    COSMOS
    36-7604, 36-7604-E
    CPC
    VRND-378
    DUBOIS
    107320
    HONDA
    31150-PD1-004
    HUCO
    132975
    J & N
    230-52006
    JUST PARTS
    NP1-6002, NP1-6014
    LUCAS
    UCJ412
    NEW ERA
    IVR-510, IVR510H
    NIPPONDENSO
    126000-0340, 126000-0400, 126000-0510, 126000-0650, 126000-0700, 126000-2370
    RCP
    YR-631
    REAL
    20532066
    REGITAR-USA
    VRH2005-4A
    RENARD
    11208
    ROMAINE ELECTRIC
    8090-4378, 8090-4378-1
    SWS
    NVR112081
    TOYOTA
    27700-63020, 27700-63021, 27700-72040, 27700-72070
    TRANSPO
    IN220, IN220E-1
    TSA
    AVND-4378
    USI
    71-30003
    WAGNER
    W085-06
    WAI
    35-8204
    WOOD AUTO
    VRG4677
    ZORKOS
    Z8090-4378
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Nice info.
    As for the USI regulator, I still have it in my alternator, and to date it's still working just fine. Maybe you should give it a try and see how it does for you.
  14. f355spider
    18,047
    Well the Regitar worked fine too...for about 8 or 9k...then failed. And now this thread appears to confirm that they often fail at that point. I don't think we have enough user feedback on the USI for me to switch when my oem is still working fine. But once we have some firmer data points on one particular brand, I would like to pick up one.
  15. gus355
    Aug 3, 2011
    569
    B.C. and WA
    OK, so right off the top I would pick only two of those.
    HONDA
    TOYOTA.
    That is it.
  16. f355spider
    18,047
    I would imagine that if you can get them, they are simply relabled Nippondenso parts, since the alternators they use are ND alternators...pretty much what all Japanese makers use.
  17. gus355
    Aug 3, 2011
    569
    B.C. and WA
    So - Honda does not list the part # 31150-PD1-004 anywhere.
    Toyota lists 27700-63020, 27700-63021, 27700-72040, 27700-72070 -
    All of them are superceded to part# 2770070030
    2770070030 $187.81 $0.00 $150.25
    Alternator - Voltage regulator
    Voltage regulator, camry, 6 cylinder 1991
    Parts & Prices For Estimating Only.
    Add to Cart Contact Us
    Voltage regulator, corolla, coupe, w/o gts 1991
    Voltage regulator, corolla, sedan, wagon 1991 - 1994
    Voltage regulator, celica, w/o turbo 1986 - 1989
    Voltage regulator, celica, w/o turbo, st 1990 - 1993
    Voltage regulator, mr2, to 1/92, w/o power steering 1991 - 1992
    Voltage regulator, celica 1985
    Voltage regulator, cressida 1984 - 1988
    Voltage regulator, supra, w/o turbo 1985 - 1988
    Voltage regulator, supra, w/o turbo, to 12/88 1989
    Voltage regulator, supra, w/o turbo, from 12/88, manual trans 1989 - 1992
    Voltage regulator, supra, w/turbo 1987 - 1988
    Voltage regulator, pick-up, 4 cylinder 1991
    Voltage regulator, 4-runner, 4 cylinder 1991
    Voltage regulator, camry, gas, 4 cylinder 1984 - 1990
    Voltage regulator, camry, gas, 6 cylinder 1989 - 1990
    Voltage regulator, corolla, coupe, w/o gts 1988
    Voltage regulator, corolla, coupe, w/o gts 1989 - 1990
    Voltage regulator, corolla, liftback, sedan, wagon, gas 1984 - 1987
    Voltage regulator, corolla, liftback, sedan, wagon, gas, to 4/88 1988
    Voltage regulator, corolla, liftback, sedan, wagon, gas, from 4/88 1988 - 1990
    Voltage regulator, corolla fx and fx16 1987 - 1988
    Voltage regulator, tercel, liftback, sedan, 55 amp 1987 - 1990
    Voltage regulator, tercel, liftback, sedan, 60 amp 1984 - 1986
    Voltage regulator, tercel, wagon, 60 amp 1984 - 1988
    Voltage regulator, corolla, 60 amp - internal regulator 1984 - 1987
    Voltage regulator, mr2 - internal regulator 1985 - 1989
    Voltage regulator, pick-up, 4-runner, gas, w/ic regulator - external regulator 1985
    Voltage regulator, pick-up, 4-runner - internal regulator 1984 - 1988
    Voltage regulator, pick-up, 4-runner, 4 cylinder - internal regulator 1989 - 1990
    Voltage regulator, van, to 5/84 - internal regulator 1984
    Voltage regulator, van, from 05/84 - internal regulator 1984 - 1985
    Voltage regulator, van, from 05/84 - internal regulator 1986 - 1988
    Voltage regulator, van, from 05/84 - internal regulator 1989
    Alternator - Bearings
    Bearings, pick-up, 4-runner - internal regulator 1984 - 1988
    Basically every Toyota on the planet...
    I'd go with this - Also, the REG from Toyota is $150, just think how good the $25 regitar could possibly be.
  18. f355spider
    18,047
    #18 f355spider, Nov 1, 2011
    I can confirm the proper replacement voltage regulator from Wagner is W085-114 from their website. It cross references to the Nippondenso part number 126000-1500. And in the application list mentions it fits on "Ferrari". ;)
    Big question is whether the Wagner part is any good or not.
    What is confusing with many of the cross references as I posted above is they show many supposed cross references that don't make any real sense. Nor do they cross to the factory part...though they do cross to the Regitar and Transpo part numbers...but are those truly equivalent?
    I think it is safest to ONLY use a part that is shown to directly cross reference to the factory nippondenso 126000-1500 only.
    This is the catalog I used to look up the part numbers: http://www.wagneralt.com/catalog/books/W2008-08.pdf
  19. Minhwinn
    Minhwinn Rookie
    Apr 4, 2013
    5
    OC, California
    Hi everyone. Thank you for all the information and instructions on rebuilding this alternator. I have spent a couple days reading through all the forums for this subject. I know this threat started several years ago, so does anyone have an update of where I can get replacement parts? I tried calling my local alternator shop and they just don't sell the parts. Can someone recommend? I am in Southern California or website would be great.
    Looks like I need a regulator, rectifier and perhaps bushing.
    Thank you!
