Rejetting carbs | Page 4 | FerrariChat
Rejetting carbs
Discussion in '308/328' started by Hans, Aug 27, 2007.
  1. jmillard308
    jmillard308 F1 Veteran
    May 29, 2003
    6,696
    Perth West Oz
    John Millard
  2. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    not really interested in more HP.....just want to get it running right, really.
  3. marankie
    marankie Formula Junior
    Aug 30, 2004
    252
    Agoura Hills, Calif
    Martin
    Wonderful stuff Aircon. I have a '75 GT4, so I am particularly interested in your results. Did you try 135 mains with different Air Correction jets? (Right now I have 60, 135, 200, F36)
    Thanks,
    Martin.
  4. Aircon
    100,524
    Peter
    60 idles? i can't comprehend how rich that must be running....i have 12.5:1 with 55s!
    i also have the F36.
    i found the 200 a/c leaned it a little up high. as you can see, the 170 a/c richens it a tad. something between it probably spot on, but i'm satisfied with the main circuit. i'm going to play more with the idle circuit though.
  5. marankie
    Aug 30, 2004
    252
    Agoura Hills, Calif
    Martin
    Hello Aircon
    Well, my car came with 60 idles (actually 55s drilled out to 60s) It pays to check the jets with a gage, because lots of "tuners" drill out jets without filing off the numbers.
    I now have a set of 55s which I will install at first oppertunity.
    The car originally came with 220ACs, which I changed to 200s. A noticeable improvement on top end. Mid range is excellent. I think I will try to buy some 180 ACs.
    You dyno chart comfirmed what I have suspected for some time, and that is there is no point in reving beyond 7200 rpm. It is past max power point and considerabley past max torque point.
    In fact because centrifugal rod bearing loads go up with the square of the rotational speed, reving beyond 7200 rpm unneccesarily loads and wears engine internals at an increased non linear rate. Particuarly so for 30 year old engines, and that means increased risk of faster rate of wear and or break-down.
    Thanks again for sharing your testing data. It is helping me considerably.
    Martin
  6. Aircon
    100,524
    Peter
    i'll let you know how i go with my 50s which i might be drilling out to 52 before settling for the 55s
    ohhhh...good thinking!
    i also have quite an aggressive advance curve which helps with the flat power curve. it'd be interesting to see if like more than the standard total advance at the higher revs, actually.
  7. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    Aircon:
    Would you care to divulge a bit more on that advance curve?
    I have great interest in the subject and am always wondering how far folks have pushed it... :)
    Thanks!
    Rob Stewart
  8. Aircon
    100,524
    Peter
    i'll have to get back to you...i don't have the numbers handy.
  9. Aircon
    100,524
    Peter
    using the 55 idle jets produces and overly rich mixture 12.8:1 apart from slightyly down hill straights, where the throttle is closed almost entirely, and it is very lean there.
    mechanic said can't go smaller jets cos that would make it worse. regardless i put in the 50 idles....i'm not sure what mixture i'm getting yet...but it'll obviously be better....and because cruising required more throttle with the leaner mixture, i don't really get the light throttle popping.
    not theres juts a stumble when the transition occurs ,,,,i might be able to live with it.
    more work to be done.
  10. jmillard308
    May 29, 2003
    6,696
    Perth West Oz
    John Millard
    If you get it running right, it will make more power - really!
    It won't run right if the exhaust is an inhibitor - if the GT4 is anything like the std 308 exhaust, you are leaving a lot on the table.
  11. Aircon
    100,524
    Peter
    it's not the standard exhaust. it's an ansa, i think...so it's definitely flowing better than a standard one.
    the car is now very smooth with lots of grunt.
    just got to fine tune the idle circuit and i'll be laughing.
  12. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    I'll be putting together PeePee's test tube with wideband O2 sensor next week to see what mixtures I am really looking at on my car.
    From driving, I've got the feeling that I am still way rich on the idle circuit, slightly richt on the mains, up to way rich at the high end of the rpm scale. But it'd be much nicer to know if this indeed the case...
    Once I have the results, I'll post them here for you guys to look at and give advise :)
    In the mean time, could someone please give me a 101 on weber tuning?
    What I understand is that we have 3 entities to play with:
    Idle jets
    Main jets
    Emulsion tubes.
    My idles are 55, my mains are now 125 and I have 220 (I believe) tubes.
    How does this all come together?
    * Idles work up to 4000 or so rpm.
    * Mains take over from there. Is this a gradual take-over? Is it additional? I mean, is it idles PLUS mains at 6000 rpm, or just the mains?
    * Emulsion tubes: the higher the number the more they lean out at high rpm?????
    Does the float height have any play in this (and therefore: should this be the starting point of all tuning, to get these equal), or is it just as long as they are within reasonable range, your mixture will all be the same?
    Thanks guys!
    Test results will follow in a week or so.
    Hans
  13. jmillard308
    May 29, 2003
    6,696
    Perth West Oz
    John Millard
    Plus Air Correction jets and chokes.
    Your tubes won't be 220, that will be AC jets
    ET's are a letter and number - eg. F36
    How does this all come together? - Ah, the black art!!! :D
    FIIK
    Good luck - you'll enjoy the experience
  14. Aircon
    100,524
    Peter
    i hope you enjoy it as much as i have been.
    unless you have F24 emulsion tubes, your 125/220 mains will be FAR too lean, i reckon.
    If you have F36 emulsion tubes, your 55 idles will be too rich....i'm not sure if F24 ETs will make that even worse...probably not.
    I had 12.8:1 AF ratio with the 55 idles.
    i'm still not sure what I have with the 50s i have in there now.
    I found that not having the float levels absolutely identical made the car run like crap. how important it is that they're at exactly the factory height, i can't say for sure...i did mine at 47mm for reasons that i won't bore you all with.
    suffice to say that when they weren't identical, the car ran terribly with the 50 idle jets. now it's almost perfect.
  15. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    I've got F24's
    And I am WAY rich. Spitting out flames like mad. Locally, my Dino has received the nickname Blue Flaming Beast, for the flames up to 2 feet that I am barking out of my exhaust when I release my throttle.
    Okay, so I'll start by checking float height. I believe that Birdman has a writeup on that on his site.
    Then what exactly is the function of the air corrector tubes?? What will going up or down accomplish, mixture-wise?
    Hans
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #91 snj5, Sep 30, 2007
    While my settings on the 3.2 qv do not exactly mirror the 3.0 requirements, I thought I would just post a couple of references test graphs (and I have a lot) from a dyno pull and using an Innovate LM-1 mobile A/F recorder which I use to tune my carb jetting in addition to the dyno. The dyno only really tells you about behavior under full load, which is good as this is where the most damage could happen to the engine.
    Just for reference this is with a 3.2 qv with 140/F24/190/53 on 34mm venturis on the dyno run; The street run was an experimental run on 36mm venturis and 135 jets and 60 idles- hope this is interesting for some.
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I think one item thats not been well discussed, is the crossover between each area. The idles work in the area where the throttles are nearly closed. Even at highways speeds, as long as your not accelerating your running pretty much off the idle circuit. When you open the throttle, depending of engine rpm and throttle opening, the mains will come in through higher airflow at the venturi. At higher throttle openings at higher rpm's, the idles will drop out and not be a factor. So not only engine speed, but your foot in unison, control the airflow.
    The emulsion tubes are still a great mystery and no one seems to have a great deal of knowledge of how they control things, but obviously they are making a great deal of difference. Back before the emissions craze, cars got very good economy. Then they made the cars run rich and get horrible fuel economy to lower emissions. Catalytic convertors need even more unburned fuel to operate efficiently. Somewhere back in the past there is information to make these engines run like they were meant to. Perhaps we should be looking at the jetting of the late 60's 365 GT engines as well as ignition advance numbers to lead us. I am of the opinion that these engines could give both good economy AND good power, if we could only find the best jetting combination, and I think the emulsion tube holds a large key in that discovery.
  18. Aircon
    100,524
    Peter
  19. marankie
    Aug 30, 2004
    252
    Agoura Hills, Calif
    Martin
    You know, I think that rich idle jets do/can mask a lot of improperly adjusted carbs, particularly on the carb to carb balance, float valve heights and idle adjustment screws.
    Conversely, that means if you lean out the idle jets,to get the ideal AF ratio, the carb adjustments need to be spot on.
    As discussed previuosly, main jet size really only becomes a factor at higher power settings.
    Air correction (AC) jets realy only come into play at high power settings AND HIGH REVS. And that is where you never want a lean mixture. In fact it is better and safer to err on the side of a slightly richer mixture at max load and RPM. This will help prevent pre-ignition, keep combustion and valve temperatures cooler, and keep the engine in one piece. This is particularly important in sustained high speed running, and track conditions.
    Martin
  20. Aircon
    100,524
    Peter
    i'm with you on that. hence my 12.5:1 a/f ratio on full throttle.
    i tried the .50 idle jets before and it didn't run very well...i decided to redo the float levels...and that's ALL i changed...and they weren't perfect...now they are (sync was already spot on) and now it's excellent (for a carby)
    i'm just waiting for a new sensor for the portable analyser, then i can see what the actual a/f ration is with the .50 idles....but the plugs look quite good.
  21. Aircon
    100,524
    Peter
    just thought i'd mention....i'm hopeless at setting the idle mixtures!!
    i don't know if i'm deaf or what the hell is going on, but between the fans coming on, and whatever else, i reckon i'm lucky if i'm withing 1/2 a turn of where they're meant to be!!grrrrrrrrr
    it's running great, though.
    how are you going with your experiments, Hans?
  22. Aircon
    100,524
    Peter
    ok. all testing done today.
    Basic setup is .50 idle jets, 135 mains and 170 a/c
    cruise and light acceleration is all 13.8-14.2:1
    as soon as you reduce the throttle position, like on a slight downhill, it goes even leaner...too lean...but it did that with the .55 too.
    The car does not like running leaner than 14.5:1, really, but from 14.8:1 and leaner it's quite fluffy. This is, of course, only downhill and under "slowing down" conditions, so is of no consequence. The main thing is that on steady cruise from 2000-4000rpm it's pretty much on 14:1 average. It's not what i'd set up fuel injection to do, but it's pretty damn good.
    There is a slight lean spot at the transition from the idle to the main circuit. It's so minor that sometimes it's actually hard to find, but it goes up to 15.5:1 for a milllisecond....this was masked by the 12.8:1 mixture that the .55 idle jets had.
    For me, I'd rather keep the .50 idle jets and put up with that little burble during the transition.
    with the 135 mains, as previously stated, it's pretty much 12.5:1 everywhere on the main circuit, all revs and all throttle positions.
    I think this is the end of the experimentation, as i don't believe it could be any better than that without major modifications to the carbs,
  23. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think you've done a great job - theproof is in how it runs and you have the mixtures solidly in the power band.
    Congrats! Would love to see some graphs if available.
    I'll be doing the same as you except breaking some new ground changing from 40 to 44 DCNFs over the next 2 - 3 months.
    Again, well done!
  24. Aircon
    100,524
    Peter
    thanks. it's been fun
    i only have this graph for the full throttle curve (i forgot to say i have F36 ETs)
    the rich dip at 2000rpm was only temporary and from the accel pumps.
    http://pless.com.au/cars/gt4/rebuild/images/308dyno.JPG
    as far as a graph of cruise, it'd just be a flat line from 2000-4500rpm!
  25. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hans Teijgeler
    Tube is done. Just need to find the time to do some test runs. Problem now is that one of the radiators of my plane has burst and I need to give that some attention. Then I'm going to LA for 10 days. After my return, I'll run the tests....
    Thanks for asking!
    Hans
