RELAYS | FerrariChat
RELAYS
Discussion in 'Technical Q&A' started by fatbillybob, Sep 14, 2014.
  1. fatbillybob
    Aug 10, 2002
    28,979
    socal
    Lets start a discussion on relays. In an effort to improve Ferrari electrical reliability I'm looking into relays. There are several failure modes of our Bosch mechanical relays. Age plays a big factor. Environmental conditions like Heat does not help either. There is a whole world of solid state relays with increased reliability over mechanical relays. With some number near 15-20 relays per car, relays could be one more source of Ferrari reliability problems. They do not go bad often but sometimes they can be a real head scratcher especially when they act intermittent and fool you into thinking they are OK.
    Three unacceptable methods of getting running again (because I did not have a new relay handy) are to open up a relay clean it with contact cleaner and reassemble, another way is to flat file the contacts with a special contact tool, a third way is to energize and de-engergize with direct battery power to the 86/85 terminals 20+ times sort of like working a sticky door. The fact that these kluges sometimes work means that we have to find a better way.
    Some solutions might be to convert to solid state relay if they exist for our application. Another might be to convert to nice reliable Japanese relays. Another might be to preemptively change out relays like during a major service.
    Comments?
  2. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I'd replace/upgrade the fusebox before I even started looking at the relays, but I'd be interested in higher reliability replacement relays, even though I've never had one fail.
  3. Rifledriver
    37,089
    The mini's were never really a problem. Many of the 80's cars are still running around with the originals, still trouble free. The micros are a real problem. I keep a bunch here on hand and replace them regularly. Brand has not seemed to matter. It seems the small, lighter gauge wiring and minimalistic relays are just here to stay for costs sake. Cost savings in electrical components, especially in cars that are more dependent on it than ever has really compromised the long term viability of cars. The industry wide plan to switch over to a higher standardized voltage for passenger cars has been put on hold due to the inability of much of the cheaply made componentry to cope with it. They are caught on the horns of a dilemma.
    Cars from the 60's, 70's, and 80's will be around running long after the Kleenex generation cars are long gone. I like the modern tech in cars as much as the next guy but it is just not built to last. For most cars, that's OK. Throw them away every few years and get another but in the case of Ferrari's people want to keep them around a while. Everyday it makes me happy I am nearing the end of my tenure doing this and not the beginning or I would have put plan B into action long ago.
  4. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Sounds like a great idea, and shouldn't be too difficult for the standard 2 low power pins to complete the high power circuit type, but I know on the 348 for the ABS system there are 3 relays that are each specific to their applications with no substitutions. Knowing Ferrari, there are probably many other cases of weird only-made-for-this-model relays that may be impossible to replace.
  5. fatbillybob
    Aug 10, 2002
    28,979
    socal
    We have at least three fusebox solutions that seem more robust than factory so that takes away one giant source of potential problems.
    I have had many relays in Ferraris over 30+ years (as a DIY'er and helping friends) intermittently fail, the worse kind of failure. Chasing your tail is the worst possible diagnostic situation. Very few relays in my hands have out right failed. Sometimes you can just pull a relay and wack it on the table and it will work fine again. That is not a characteristic you want in your electrical system hence this thread. If we could make everything just a little more robust we could have a daily driver level of reliability in a Ferrari.
  6. Cribbj
    Cribbj Formula 3
    Carl, you know my feelings on this. Get the high current loads like the fans & fuel pumps off the main fuse/relay board, then replace all the relays every 5 years or so. $25-$50 for peace of mind is chump change.
    The high current loads need their own dedicated feeds, and the radiator fans need 75a relays. Ferrari may know their engines, but they don't know squat about electrical systems.
  7. fatbillybob
    Aug 10, 2002
    28,979
    socal
    I doubt that if the brain trust just bothers to take a look at requirements. For example why does the 550 on the fuel pump circuit use the xxx140 relays (5 pin) instead of the xxx103's (4 pin pin) so prevalent in the fusebox? If you look at the fuse box itself the 87 or 87a pin on the box does not exist (I will have to open the box to be sure its hard to see). So a 4 pin of same amperage could have been used. I only glanced at that because there are 4 fuel pump relays for the 550 two on left and 2 on right and an odd mix of xxx140 and xxx103 relays
  8. fatbillybob
    Aug 10, 2002
    28,979
    socal
    Yes and yes! The question I have is how much more robust is a new relay vs. a 5y/o one? I rarely mess with relays only thinking about this project to make things more robust. How many in 100 new relays fail upon installation if that even happens. Mechanical stuff just has an inherent failure rate that solid state does not right?
    Moving high current loads has got me thinking about relays. I'm figuring out how to move all those high current loads closer to the fans for example as we spoke about before. But that system reliability has the weak link of the Ferrari stuff upstream of it. So I'm investigating relay robustness not only for the footwell fusebox which only gets hot but the engine bay "close to the source high current loads" that live in a dusty, dirty, hot, wet, and oily environment.
  9. Cribbj
    Cribbj Formula 3
    I don't know that SSR's are the answer here because they don't have the form factor that we need for plug-in replacements for the Bosch's.
    Most people never worried about replacing relays in the past because their lives were usually greater than a million operations or so. But with higher amperages and higher spike levels, those lives are reduced quite a bit. This is why we now ought to consider relays as consumable items that need to be replaced periodically, like timing belts.
    Do you know that in the electrical world, fuses are now considered wear items and are recommended for periodic replacement? It's true; high voltage fuses that have operated at, or near their rated interrupting ability are considered to be "weakened" and are now recommended to be replaced periodically. This philosophy hasn't trickled down to the 12v automotive world just yet, but there's no reason for it not to.
  10. JCR
    JCR F1 World Champ
    10,903
    H-Town, Tejas
    At what point do you just bite the bullet and go to a PDU/PCM (Motec, Life Racing, OBR, etc.)? Worse than the relays are the multilayer fuse panels.
  11. Cribbj
    Cribbj Formula 3
    Those modules are an interesting solution for people who are building "new" cars, racecars, or kitcars. But I don't believe they're viable for the retrofit market that we find ourselves in.
    I really do believe the most effective path to increased reliability of these main fuse/relay boards is:
    1. Get the high current loads out of the main fusebox/relay board and onto dedicated feeds
    2. Replace the existing relays periodically
    3. If/when possible, insulate the footwells and engine bay in front of the footwells.
  12. fatbillybob
    Aug 10, 2002
    28,979
    socal
    As we know it is really hot in our footwells. I have thought about splitting off some of the A/C and running it in the footwell.
    It will be interesting to see how you insulate this area with your engine out for access.
    Do you think that the bosch relay looses its ability to maintain an electrical switch for the high power side as the heat increases?
  13. fatbillybob
    Aug 10, 2002
    28,979
    socal
    Agreed. Working solutions have been
    1-breadbox rewiring (I did a thread on that and it is still "currently" working)
    2-SRI repair (I do not know what SRI actually repairs or how)
    3-Birdman style new fuse panel rewires
    4-Other vendors exist who can remanufacture the multilayer film boards with improved properties that no one has tried to my knowledge
    I have owned 6 Ferraris and they all have had issues in their fusebox. I have helped friends fix their problems too. This appears to be a universal Ferrari problem. At least 1 thing in just about every car does not work with the rule of italian wiring prevailing where if you fix that one thing the next thing that breaks could be something you really want. Fixing the fusebox seems to really help this problem.
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    Right, any electrical component that has to make or break live loads are going to wear, no way around the physics of it. Fuses and resistors are also going to have a life cycle as the metal employed cycles thru micro-fatigue from heating/cooling thermal stresses.
    Automotive circuits as much as we like to think of them as DC are not true DC when the alternator is on-line. there is a ripple in the current and voltage, add in transient spikes from switching live loads and components are going to eventually fail, esp those with diodes in them. The battery while only having a potential of ~13V has a massive amount of current capability, that is why contact relays take a beating, micro welds every time it's cycled.
    I'd be more concerned with the fuse panel mylar and cold solder joint fatigue, toss in the undersized wire gauge and bad grounds, corrosion at the terminals and when current goes up due to increased resistance.. melted insulation and burned out contacts. The battery has more then enough capability to weld all the terminals in a vehicle.
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    That would depend on the relay, being that it's an electromagnet it doesn't really rely on permeability of it's core. If it did then heat would effect it's ability to hold the circuit. There's probably more heat generated within the back EMF resistance and transients then external ambient heat.
    If the relay has circuit components of diodes or film resistors then heat can become an issue.
  16. Steve Magnusson
    26,779
    Feel your pain, but SSRs have some downsides that are virtually unacceptable for a car -- they are "leaky" when off (so the battery would be deeply discharged overnight), heavy, and need a lot of cooling (especially if you had 10~15 of them in the same space) = big heavy heatsinks and probably some air fans too. The little electromechanical relays aren't perfect, but they make a lot of sense for a car.
  17. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Furthermore SSRs do not galvanically isolate the load circuit. There's "only" a switched off semiconductor, not an isolating air gap.
