Remake a sun roof part | FerrariChat
Discussion in 'Mondial' started by Mondial83, Jan 7, 2016.
  1. Mondial83
    Mondial83 Formula Junior
    Nov 8, 2014
    685
    #1 Mondial83, Jan 7, 2016
    Can anyone make this part? It is the guide on my sun roof the driver side is missing and I noticed this is cracked. So I need two. Any idea of where I can get them or if some one could make them?
  2. Mondial83
    Nov 8, 2014
    685
    #2 Mondial83, Jan 7, 2016
    Also should there be a peice on this that fits in the pully on the flat peice on the back of the sunroof. I noticed a small round peice laying in the back I haven't gotten it out yet does it being here?
  3. Mondial83
    Nov 8, 2014
    685
    Also any idea where I can get a new seal for the sunroof itself
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    My experience seals and gaskets are not expensive at the F dealer. I just bought a new rear window rubber for 150 USD at the dealer. I would get it there and at the same time see if they have the other part as well. You can always decide not to take it after knowing the price :) but then you have at least the part number.
  5. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,101
    PB County, Florida
    Jerry
    I am told the sunroof seal on my 89 t is the same as the BMW e28 ( 5 series). I am guessing same for the earlier models.
    Regards,
    Jerry
  6. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I believe this stuff hasn't changed since the first Gen Mondials. When I look at the parts they all mention QV, 3.2 and T. The 8 simply has no partnumber list available online so it is not that list. I have no idea if BMW has the same. Look and compare :)
  7. Mondial83
    Nov 8, 2014
    685
    Which BMW series you think? I can't find it on an 8 diagram either so no part number
  8. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    I read in some forums that a few European cars of that era shared the same sunroof mechanisms.
    ie. BMW, MB, Ferrari, etc.,
    I have not vouched the info, so don't take it as gospel.
  9. Mondial83
    Nov 8, 2014
    685
    I have taken it all apart. I need the entire mech. All plastic is broke croaked missing. So I need the mech and arms and the slide and the peice the cable goes to inside the slide. anyone???????
  10. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Yep, I do. If you explain me how to dismantle the mechanism without breaking anything.
  11. Mondial83
    Nov 8, 2014
    685
    I can do that. Slide sunroof open all the way. Remove the two tiny screws in the rails at the front. Pull rails out. Pull sunroof forward until the front feet are in the section that is cut out on both sides where the rails were. Soon as you get to that area pull upward and towards you. The roof will come out. There is one nut holding the mech in. Take that nut out and remove the slide. Then take the rest out carefully not to break the parts on the ends. I also need the cable car the plastic peice that is on the end of the cable that slides the roof back and forth.
  12. Mondial83
    Nov 8, 2014
    685
    I could also use the outer seal that is on the sunroof itself if you have that as well.
  13. Mondial83
    Nov 8, 2014
    685
    #13 Mondial83, Jan 8, 2016
    I need the following parts I don't need the slide just the round mech with the arms on it and the plastic pieces must be in good order. You can see mine is missing one end and the other I badly cracked
  14. Mondial83
    Nov 8, 2014
    685
    #14 Mondial83, Jan 8, 2016
  15. Mondial83
    Nov 8, 2014
    685
    This peice has a nub missing you can see it is broke off in the center. This one I could fix the others I can not
  16. Mondial83
    Nov 8, 2014
    685
    I have been unable to find any BMW parts that look like these
  17. Mondial83
    Nov 8, 2014
    685
    #17 Mondial83, Jan 10, 2016
    I no longer need sunroof parts. I purchased the parts I needed at a astronomical price. There is a guy in Belguim Redbaycars.com if anyone needs reasonable parts he is the guy. Contact him if you do t see what you need and he most likely will have it.
  18. RicSinger
    RicSinger Formula Junior
    366
    Rancho Santa Fe
    I am also needing the white plastic parts. does anyone know where can I get them?
    I’ve spoken to Stefan at Redbay parts and he doesn’t have them.
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,958
    Isle of man- uk
    Have a look at Porsche for bits, i recall someone saying it was the same. Then get doctors appointment as messing with these will do your mental health in.
  20. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    545
    NYC
    Joe
    Dan Noble on ETSY has reproduced all of these sunroof parts
  21. 85QVEuro
    Jan 15, 2021
    545
    NYC
    Joe
    OK - shout out to Dan Noble (see link in post 21 above) with assistance from FerrariChatter, wilkrod. I had several issues with my sunroof and needed numerous replacement parts including the three guides on the edges, the end pieces for the swivel (post #18 above), the top plastic guide that goes on the piece with the cable (post #2 above), etc. etc. After a user error on my part required a repaint of the sunroof, I sourced a bunch of new parts from Dan and finally got it installed this weekend. For me, the hardest part was getting the aluminum "wings" on the back of the roof to slide into the guides. In any case, from what I can see from the Etsy listing, they have all the parts I needed and pretty much every part for the sunroof (except the motor/cable stuff). Some of the parts have been upgraded with better/stronger plastics and better designs. So overall, a good resource and very helpful vendor which is appreciated when you are dealing with something as finicky as the sunroof.
    ellum likes this.
