Remanufactured fusebox for Mondial/Testarossa/3x8/400 range | FerrariChat
Discussion in 'Ferrari Parts & Collectibles' started by stekkefun4, May 29, 2016.
Thread Status:
Not open for further replies.
  1. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    #1 stekkefun4, May 29, 2016
    These are made in Belgium and hold high quality materials from the USA, Switserland and Belgium. They have all passed an elaborate quality verification process and are of much better quality than the standard Ferrari OEM fusebox boards made in the 80's and 90's. These boxes will withstand the test of time much better than the original ones and will guarantee many years of fun with your precious classic car.
    Remanufactured fusebox boards for:
    Ferrari 328 GTB / GTS and GTB Turbo
    Ferrari Mondial 8, QV, 3.2 and T
    Ferrari 400 and 412
    Ferrari F40
    Ferrari Testarossa, TR and 512TR
    Manufacturing process:
    -2mm thick board gets drilled with all holes in exactly the same location as a standard board.
    -All connectors get attached to the board together with all electric wiring, now making use of bigger 2-pin plugs instead of the thin single-pin plugs on OEM boards. During this process, all connections are continuously put to the test.
    -The board gets protected with an anti-static insulating varnish against dirt and corrosion.
    -The board passes a final quality check before being packed and shipped to a happy customer.
    Technical specifications:
    -Board has a thickness of 2 mm (DIN norm EN 60893 / DIN 7735 Phenolic sheet) instead of 1.5mm OEM
    -Connectors made in Switserland and the USA
    -Wiring is VOB 2.5 mm2 (VOBBL2,5R) insulated electric wire from Vinckier (Belgium) CEBEC conform. Maximum throughput: 500 V X 25 A, that is 12 V until 1000 A
    -All soldering done with high temperature silver/tin/lead alloy solder.
    These remanufactured fusebox boards have exactly the same dimensions and lay-out as the OEM boxes and all relays and fuses will fit 100%. The sale includes the motherboard and female connectors to put on the wires. NOT included are fuses and relays. Fits the new syle fuses and relays.
    Price is of 650 euro excl taxes and shipping.
    A number of F-chatters already have one installed and are very happy with it.
    PM me if interested.
  2. stekkefun4
    2,232
    Belgium - Europe
  3. stekkefun4
    2,232
    Belgium - Europe
    updated installation manual is available
  4. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,313
    Germany
    Steven
    #5 st@ven, Jun 26, 2016
    Looks great.
    i took my box apart several years ago to fix an issue on one of the layers. This looks definetely more robust. Knowing how the oem build-up is, can you show some pictures of the backside? And details of soldering?
  5. stekkefun4
    2,232
    Belgium - Europe
    #6 stekkefun4, Jun 26, 2016
    This one is as robust as the russian Soyuz space rockets! Here's a detail of the soldering: manually done and easily accessible.
  6. stekkefun4
    2,232
    Belgium - Europe
    Currently in stock : 1 x 400 model and 1 x Mondial QV. Other models can be delivered within 1 to 2 weeks.
  7. stekkefun4
    2,232
    Belgium - Europe
    Update: currently in stock: 3 x Mondial QV, 2 x Mondial T, 3 x Testarossa
  8. braq
    braq Karting
    Mar 29, 2010
    227
    Hill Island
    Paul XXXcX
    Hi, not sure about the part 12V until 1000 A, because
    if it is good for 25A, then this it.
    the voltage is about the distance to the next conductor.
    cheers
    braq
  9. stekkefun4
    2,232
    Belgium - Europe
    These are left for sale:
    1 x Mondial QV
    2 x Testarossa
    1 x 400i
    1 x 328
    New fuseboxes will be available again only in May next year! Be fast to get yours, almost sold out.
  10. enzo52
    enzo52 Karting
    Aug 14, 2008
    131
    France, Paris
    Depensadie Seraphin
    I have this fusebox reproduction more then 8 years in my car and I even forget about it.
    Very happy with it since, no more burned connectors or electric gremlins.
    I know that Guido, who produces those boards, test them with 220V/30A resistants to find any mal function before approval.
    Enzo52
  11. stekkefun4
    2,232
    Belgium - Europe
    Left for sale:
    1 x Testarossa
    1 x 400i
    New production batch will start in May 2017
  12. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    346
    Reisterstown, Maryland
    Mark
    Price on the Testarossa board?
    Thanks Mark
  13. stekkefun4
    2,232
    Belgium - Europe
    650 euro ex VAT andshipping like all the others. I have a last one available.
  14. dontilgon
    dontilgon Formula Junior
    May 30, 2011
    332
    NY/PA
    Joseph
    Will you be making any for the 512TR?
  15. stekkefun4
    2,232
    Belgium - Europe
    We need to have an example of a 512TR box first before we can remanufacture them. If you're OK with sending us your board first, then we can make one for you.
  16. stekkefun4
    2,232
    Belgium - Europe
    for the moment one fusebox available for a Testarossa
  17. stekkefun4
    2,232
    Belgium - Europe
    For the moment none available, production will start again in May. There's a waiting list, so if you need one, please let me know ASAP.
  18. fjamo
    fjamo Rookie
    Aug 13, 2016
    4
    Hello
    Had the specialist repair the damaged part of the existing cuircuit board and put extra switch for Airco, Cooling Fans and Pump.
    Should do the trick, if not I'll be back.
    Frank
  19. stekkefun4
    2,232
    Belgium - Europe
    Production has started again :)
    Currently reproducing 2 F40 fuseboxes!
    Waiting queue is of 1 month now and will be reduced further.
    At the moment 1 fusebox of type 328 available! If you need one, be FAST!
  20. Alden
    Alden F1 Rookie
    3,616
    Central Florida
    Do you mean they put in an extra "relay" off the board somewhere? Or a "switch" of some kind.
    Details?
    Alden
  21. stekkefun4
    2,232
    Belgium - Europe
    328 was sold in 1 day...
    The waiting list is empty again, many units have been sent all over the planet.
    Average waiting time now is just a couple of days.
  22. Casino Square
    Casino Square Formula 3
    1,728
    Hong Kong / USA
    Andrew
    Is there any chance you will produce one for the early 308 (77, USA model)?
  23. stekkefun4
    2,232
    Belgium - Europe
    Not in the near future.
  24. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Hi-
    How long for a 1984 400i board?
    Previous owner replaced the 400i board with one from a 412, claiming the 412 board was better. Is that accurate?
    Thanks,
    Jason
