488 - Remote exhaust valve with standard exhaust | FerrariChat
488 Remote exhaust valve with standard exhaust
Discussion in '458 Italia/488/F8' started by Jonny English, Oct 28, 2020.
  1. Jonny English
    Jonny English Formula Junior
    Jun 14, 2017
    416
    Poole, Dorset
    Jon
    I drove my 488 last night and it sounded fantastic at full chat. However it is a bit annoying how at lower revs and goes in and out of "loud" mode. Instead of fitting a new exhaust I'm now thinking of fitting a remote exhaust valve to the standard exhaust. Is it a plug and play device? any recommendations/ suggestions?
  2. Hopeful
    Hopeful Karting
    May 31, 2019
    156
    Vero Beach, FL
    Tony M.
    Yes, plug and play. I went with the one from Forza and love it although a lot of people use one from Capristo. Either is about a 2-3 hour install, either with the rear wheel well covers off or with the rear bumper off. You can also just unplug the vacuum lines and plug them with a golf tee or something similar but I like the ability to revert back to factory operation at the push of a button. Plenty of threads on this.
  3. Viperjoe
    Viperjoe F1 Rookie
    As said here many times before, simply unplug the bypass valves and enjoy the symphony throughout the entire RPM range.
    scott61 and Cigarzman like this.
  4. Jonny English
    Jun 14, 2017
    416
    Poole, Dorset
    Jon
    How do you do that?
  5. Cigarzman
    Cigarzman F1 Veteran
    The F dealer did mine at no charge. Disclaimer: I am mechanically challenged. Lol
  6. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Plenty of threads on doing it here. It's an easy job that i have done myself on other cars but on the 488 rear diffuser needs to be dropped to get at it. Since would be a pain without a lift I had dealer do it, took just over an hour and cost a few hundred. Car now sounds great all the time, don't waste your money on a controller since you will never want to shut them
  7. Graz
    Graz Formula 3
    Oct 15, 2012
    2,329
    New Jersey and Florida
    Graziano
    I have the Capristo valve system on my 458. I push the remote use once in a while just for kicks as the stock exhaust is excellent on its own. The car had it installed when I purchased it so......
  8. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    If you bought your car from a dealer just get them to do it. Plug the air lines of add a controller. Controllers are cheap and you have the flexibility and let it run the way Ferrari designed it to work. Or like I did and Ferrari unplugged the values free of charge when i picked up my car.
    At the end of the day it will be up to you. Discuss both options with the dealer. Which unit for a controller ? Flip a coin.
