Remote Issue---Need advice | FerrariChat
Discussion in '360/430' started by trialman1, Jun 13, 2010.
  1. trialman1
    trialman1 Karting
    Oct 18, 2008
    72
    new york
    steven
    I have 2 remotes for my 2000 360. I don't have the red remote. Replace the battery in both a month or so age and they were both working fine, now 1 of them blinks red but nothing happens. the other 1 works just fine.
    Any help will be greatly appreciated.
  2. tazandjan
    39,175
    #2 tazandjan, Jun 13, 2010
    Steven- Repace the battery again and try pinching the contacts closer before inserting the new one. Make sure there is no corrosion on the contacts. A weak battery or bad connection may provide enough power to illuminate the red LED, but sometimes not enough to disarm the alarm/immobilizer. Been there, done that. I recommend Duracell batteries because I have never had one leak, and other batteries have, including Energizers.
    Read this if you have insomnia tonight. Explains all about the Alarm System and the alarm fobs. It has an image of the battery you want.
    Taz
    Terry Phillips
  3. Skidkid
    Skidkid F1 Veteran
    9,531
    Campbell, CA
    John Zornes
    Also, unless you did the antenna mod you have to be very close to the car for the remotes to work. The alarms antenna is in the panel behind the drives seat. It is behind a metal bracket that effectively isolates it (think Faraday cage). There is a thread with full pictures on how to pull it out of the metal enclosure. Quick, easy, and will make your remotes work from distance.
  4. snoble
    snoble Karting
    May 10, 2010
    118
    San Jose/Shanghai
    Steve Noble
    Ah hah! Here I was trying all my remotes trying to figure out why they only work from about 4 feet away! :)
  5. Skidkid
    Skidkid F1 Veteran
    9,531
    Campbell, CA
    John Zornes
    The fix takes somethink like 15 min. If you can't find the post let me know and I will see if I can find something and/or help you get it done.
