Remote not responding | FerrariChat
Discussion in '348/355' started by 4respy, Feb 14, 2015.
  1. 4respy
    4respy Formula Junior
    Aug 15, 2014
    601
    los angeles
    steve
    The remote on my car does not seem to be working..See the light when I push button, but nothing is happening?..
  2. DB188
    DB188 Rookie
    Jul 7, 2013
    33
    North Yorkshire
    db
    I have the same problem with two out of the three remotes I have. My car is going in to then dealers soon to have the cambelts replaced etc and they said they would have a look then. Sorry this does not help you but hopefully as and when I can update you.
  3. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks!, This is really annoying as I only have the one remote as of now..Was going in the near future to Ferrari Beverly Hills to get the three remotes and pin recovery..I wish I did it sooner..right now useless car
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,690
    South East
    Jimmie
    Contact Gobble to see if he can retrieve the data and maybe create a clone
  5. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    99% chance I could salvage your data to a new remote (or two). I've seen this before where the remote takes a crap but the important data is still there. Try a new battery first though.
  6. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I can fix this too.
  7. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    If you have more than one fob, alternate them every time you drive or start the car.
    If I still understand these "fobs" they have a rolling code, if you use the same one over and over it puts the unused one further behind on the code. So when you try the unused one yes it blinks and does nothing .... Forever. I always alternate my two fobs, and some days I still have to hit the second one 3-5 times to get the car to beep at me.
    Don't know if this applies to your problem or not ?
  8. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    #8 vracer, Feb 14, 2015
    Is it remotely (pardon the pun) possible you guys have clones?
  9. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks for all of your responses..I will try a new battery first
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    I have pressed my clone for over 5000 times now and it has not caught up, I am going to try and bypass it next time.
  11. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    If you want I can just catch you up with the programmer.
  12. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    After taking my car out about 4-5 times in the last couple of weeks, I used my "other" key. It took 190+ clicks to hear "cheep-cheep".
  13. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Wow only 190 plus, hire the neighbor kid to sit and press it for you.
    Tell him if he gets a "cheep cheep" from the car you will give him a ride in it.
    I have one red and one black, they might both be clones ..... I did send both to gobble last year so there might be a "hint" in the line above this one ;)
  14. DB188
    DB188 Rookie
    Jul 7, 2013
    33
    North Yorkshire
    db
    So are you saying that if you get the red light on the remote when it is pressed then it might be a matter of clicking the button on the remote until it catches up with the car ?
  15. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    I have one key & a clone, so basically one key. I have found that when I lock the car - one push gets it done, and I'm ready to start, but if I leave it unlocked, it takes multiple pushes. I've counted a few times, and 7 seems to be the magic number. (All of the above with one or the other key.) Is this SOP?
    DB above - yes. If you have two original keys, each has its own program progression with the immobilizer, and either should work with one (or a few) clicks. If your additional key is a clone, and your second key has not been used for a considerable time, your finger may cramp before the car starts.
  16. DB188
    DB188 Rookie
    Jul 7, 2013
    33
    North Yorkshire
    db
    DB above - yes. If you have two original keys, each has its own program progression with the immobilizer, and either should work with one (or a few) clicks. If your additional key is a clone, and your second key has not been used for a considerable time, your finger may cramp before the car starts.[/QUOTE]
    Thanks will give it a go. Here's to thumb strain !
  17. DB188
    DB188 Rookie
    Jul 7, 2013
    33
    North Yorkshire
    db
    SORRY just realised that my problem was that when the buttons are pressed on the remotes the red led on the remote does not light up even with new batteries in ?
  18. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Sounds like your remote died. The data should still be good though.
  19. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    db,
    Gobble has successfully cloned many fobs, mine included. If this is a 'second' fob, you're ahead of the game. My car came with only one fob.
