Removal of Mondial 3.2 engine | FerrariChat
Discussion in 'Technical Q&A' started by kdross, Oct 9, 2004.
  1. kdross
    kdross Formula Junior
    887
    NJ
    Ken
    How easy is it to remove the engine in a Mondial 3.2? It looks very similar to removing the engine of a TR. Are there any tricks?
    Thanks.
    Ken
  2. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    I believe it comes out the top like the 308
  3. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    I believe it comes out the bottom attached to the rear subframe as a whole assembly. From the bottom.
  4. mondial86
    mondial86 Formula Junior
    Nov 1, 2003
    298
    MA
    David Holmes
    I did my 86 cab last year and it comes out the bottem like the 348 and the 355's.It is not hard if you have a lift ,it can be done with out a lift but much ,much easier with a lift.I made a dolly to hold the assembly on ,put it under the car ,lowered the car to the dolly ,holder ,un bolted everything and ,lifted the car up ,up and away.
    david
  5. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    I believe it comes out the front. pull the seats out, undo the wingnut, and you should be able to pull it out through the passenger door.
  6. tbakowsky
    Sep 18, 2002
    20,039
    The Cold North
    Tom
    She comes out the bottom. Not that bad to do at all. But I find them a little more time consuming to get out then the TR..I don't know why but I find them a little more difficult..may have alot to do with space limitations on the 3.2 Cabs.
  7. kdross
    887
    NJ
    Ken
    Thanks Tom. This is a 3.2 Coupe, so it should have more room than a cab. We need to do a major on the car and did not know if it would be easier and quicker to pull the engine or to leave it in the car. We are leaning toward removal.
    Ken
  8. tbakowsky
    Sep 18, 2002
    20,039
    The Cold North
    Tom
    I do the major's with the enigne in the car if it's only a belt swap,with cam covers and cam seals. Quite easy to do with the enigne in. I think if your going to replace all hoses and fuel hoses and intend to clean everything to make her look new again..then go for the pull..it's so much easier to replace all related fuel hoses with the engnie out of the car.
