removal of moulding and cover | FerrariChat
Discussion in '308/328' started by Agsurf5, Jul 20, 2011.
  1. Agsurf5
    Agsurf5 Rookie
    May 29, 2011
    46
    #1 Agsurf5, Jul 20, 2011
    i have been researching everywhere. apparently everybody knows how to do it, but me....
    how do you remove the cover from the side moulding on a 85 305 QV?
    separating part 24 and 28 from the attached (from ferrari parts).
    i do not want to break anything, but i'd like to run a wire up there for a radar detector...
  2. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    I'm not sure what we're looking at. What page of trhe WSM is that?
  3. ClydeM
    ClydeM F1 World Champ
    11,908
    Wayne, NJ
    Clyde E. McMurdy
    On my 83 GTB - your vinyl at the top of #24 looks like it's tucked behind the moulding, right? carefully coax and untuck the vinyl out. careful not to rip it as its old. slide the vinyl down about 1" where you'll find a very small black phillips screw holding the molding to #28. take out the screw. The moulding is now held in place by a metal spring clip near the base. Slide the molding up & off it pops. reverse the process for install.
  4. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    Piece 28 pops off with a putty knife. Piece 24 can be removed by drilling out 2 rivets. Piece 25 can be removed with either 6 or 8 small screws depending on the year - I think an 83 has 6 screws. Good luck.
  5. Agsurf5
    Agsurf5 Rookie
    May 29, 2011
    46
    ricambi america
    308QV: Table 111 - TUNNEL AND ROOF
    28 ok with putty knife. i can imagine it. are they just clips of some sort?
    so it snaps back in?
  6. i-velocita
    2,520
    Colorado
    James
    Yep, it just pops on and off. I think there are 3 clips.
  7. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    When he pops #28 off what will be behind that trim?
    I ask this becuase I've been thinking of poping this off myself as well (1989 GTS) to check my drain tube for a clog. Not sure if its seen after popping #28 off.
  8. i-velocita
    2,520
    Colorado
    James
    Trim #24 is behind. Must drill out 2 rivets to remove #24.
  9. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    +1 - I've done all this too.... easy process.
  10. Jdubbya
    Jdubbya The $10 Trillion Man
    43,209
    PNW
    Could be screws too. Mine was but I'm not sure if that was original or not. Yep the center trim piece just pops out.
