Removal of rear deck pieces for re-upholstery. | FerrariChat
Discussion in '308/328' started by chrisbinsb, Aug 5, 2013.
  1. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    So I'm thinking of having the headliner and other fabric wrapped pieces on my '84 redone and would like to try removing them myself for a local shop to do of possible.
    I've read the numerous threads on this and understand that there should be a bolt holding the small middle piece that holds down the left and right deck pieces but I can't for the life of me find it. I was able to easily remove the left side piece as its rivets had already been removed and can see a threaded rod running down through a fairly large hole to a round disk. I am assuming there is a nut on the other side of the disk but how to get to it?
    In the engine compartment, there's a aluminum shield at the rear and I'd guess it somewhere behind it, but I can't see even how to remove the shield. I even took my bores cope to try and look up under the shield and see if I could spot anything without any luck.
    Any tips? Does the shield need to be removed?
    Next up is removing the side windows - I've read that they just push out but any more detail is appreciated, last thing I want to do is break one.
    Thanks - here's a photo of the center piece with threaded rod and the aluminum shield I'm talking about. [​IMG]
  2. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Hi Chris, I performed this task on my 328 a while back and I assume it is the same procedure as on the 308 QV. The shield does indeed need to be removed and this is performed by removing the nuts on the threaded studs which hold the fuel line bracket in place. Once the aluminum shield is removed you can access the fastener on the threaded post which is attached to the central trim piece. Even with the shield removed it's a bit of a challenge to get to the nut. Others, I included, ended up replacing the standard nut with a wing nut to make reinstallation easier. Hope this helps.
    NashGTS likes this.
  3. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    #3 furmano, Aug 6, 2013
    As Ettore stated, the shield needs to come off. It's held in place with three nuts that also hold the fuel lines in place.
    The left and right shelf pieces are each held in place with a vertical threaded rod that I think can be accessed without removing the shield.
    To access the vertical rods, just reach back deep and feel around the underside of the shelf and you should run into the threaded rod and nut that is holding it in place. One on the left, one on the right, basically located in the middle of the shelf.
    Below is a picture of the right shelf. Notice the location of the threaded rod and the hole for the seat belt bolt for reference.
    -F
  4. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    On a parallel topic, is there a good sources for the OEM (or close to OEM) material? No, I haven't done a search yet...
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    yes
  6. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Interesting as I was able to slip out my left side panel and it did not have the threaded rod. It appeared to be secured by rivets along the side window and the center strip only.
  7. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    There is oem fabric available from re-originals and close to oem fabric from another Denver fabrics.
    I am debating what to re-do it with. I really like having the car as original as possible but others have replaced the fabric with leather, which I think would look great and make cleaning much easier. Seeing how much dirt and dust collects there, that's no small thing. For the small amount of leather needed, I doubt there would be much cost difference, but the thickness of the leather might make for some extra challenges. I'd also need to match as closely as possible the existing leather.
    Some cars where available with a leather option, but I don;t recall now if the '84 QV was one of them.
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I used this and it can be seen in my car towards the end around page 26-28 I think of my thread Crowndog's Adventure
    Found it here:
    Search Products - Denver Fabrics
    Taupe/Beige Wool Coating - Discount Fabrics
    DF#KKK988
    Taupe & Beige
    Wool Coating Fabric
    Imported From Italy
    Suitable for Jackets, Coats & Apparel
    100% Wool
    59" Wide
    Hand Wash Cold or
    Dry Clean
    $14.00peryard
  9. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Thanks! Just what I needed to know
  10. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Here it is - great photos:
    http://www.ferrarichat.com/forum/142388929-post493.html
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    That's it! I looked everywhere and there is no OEM available anywhere. Some that claimed to have it at unreal prices wouldn't send me a swatch to confirm. After looking at sites all over I stumbled on this stuff and it's wool like the original. The best part was the price.
  12. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
  13. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    Got it. I think that's a 'B' vs. 'S' thing. Re-Originals had the OEM material at one time.
    -F
  14. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    i've been wanting to do this for years but the thought of pushing the back windows out horrifies me.
  15. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Me, too. If anyone has some first hand experience or tips to share, it would be greatly appreciated.
  16. lonnie77
    lonnie77 Karting
    Feb 17, 2011
    140
    Kennedale, Texas
    Lonnie Harrison
    http://m.flickr.com/#/photos/lonnie7777/8534314809/
    Not the best way to do it . Push on the in side and work the gasket from the outside. Do not remove the vent louver hinge use a stubby screwdriver and remove the phillips screws if you plan to take it off.
  17. furmano
    Jul 22, 2004
    32,215
    Colorado
    Furman
    #17 furmano, Aug 7, 2013
    I've done it on a 328 GTB. In general, the 308 GTS is similar. Just slightly different steps. One of the keys is to use plastic body shop tools when prying out the window frame and trim.
    The GTB has rivets holding the window frame in place whereas I think the GTS has screws. Or maybe it uses rivets too, just not in the same location; not sure.
    Also, if you do have to drill out any rivets, be sure to protect your glass from a errant drill bit by covering it with a towel and tape.
    -F
  18. tatcat
    Sep 3, 2001
    11,013
    rick c
    thanks for the pics.
    they're starting to remove some of the mystery.
  19. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    Thanks for the photos and info - I had thought from other threads that the window could be pushed out from the inside but from your description, it sounds like there are screws or rivets which must be removed?
  20. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    Just to be sure, you are saying leave the hinge attached to the car, removed the screws on the louver side...
  21. pgarossino
    pgarossino Formula Junior
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    Great thread and very timely.
    I am pulling the interior out of my 84 GTS QV this weekend in prep for a full on interior restoration. I am going to need to remove that rear deck and mess with the rear windows to do all the headliner stuff. While I am in there this weekend I'll take a good close look at the rear glass and then come back here for another peek before trying anything dangerous.
    Thanks again for starting this.
    Paul
  22. lonnie77
    lonnie77 Karting
    Feb 17, 2011
    140
    Kennedale, Texas
    Lonnie Harrison
    Right. If you remove the hinges it is difficult to reinstall, they are spring loaded. Also be careful with the rear glass heater wires when removeing the panels.
  23. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    +1 had to get a helper to hold down the hinge while I reattached one, it was a pain. The spring has to be almost fully compressed while trying to get the bolts into a very awkward space. Would only disconnect the body side of them if you have a very compelling reason to do so.
    You can slightly loosen the body side to fine-adjust the hinge position though if something isn't lining up right... my driver side had walked out a bit from opening and closing for refueling.
  24. pgarossino
    Nov 19, 2009
    307
    Houston Tx
    Paul G.A. Garossino
    I was pulling the interior today. Started with the seats which came out just fine. Then I was removing the seat rails from the bottom of the seats and found that the passenger rear inside [console side] mounting bolt has a stripped head. Someone has tried to remove that rail in the past and did a bang-up job of stripping the allen headed bolt. The damn thing is tucked down in the rail and is round headed to boot so it is very hard to get anything on. Time to head out to the tool store and see what I can find to extract this damn thing........and of course to find a replacement bolt.
    Sigh..........
  25. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,327
    Montana
    Kim
    Hey Guys, when you unbolt the fuel lines from the large heat shield between the engine and cabin are you able to lift that shield out of the car if need be? Would you have to remove the decklid to do so? I need to paint or strip and polish that shield. Saw you guys touched on the topic of un bolting it so thought I'd ask.
