Removal of resin shields | FerrariChat
Discussion in 'Technical Q&A' started by Impactco, Jun 14, 2007.
  1. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #1 Impactco, Jun 14, 2007
    My car came with inexpensive resin shields already installed by a prior owner. They look cheap, are somewhat faded and are in the wrong position on the fenders. Any advice on how to remove these without damaging my paint would be appreciated. I'm thinking I'll buy some Yoshi shields to make this right per suggestion of Lee328GTS. Please don't try to talk me out of putting Yoshis or equivalent back on since I really like the look of high quality shields regardless of their correctness. Thanks!
  2. RMDC
    RMDC Formula 3
    May 15, 2005
    1,005
    Boston, North Shore
    If they are "glued" on I'd try heating them with a hair dryer to soften the glue, then buy the best 3M adhesive remover, apply that followed by a soap, water, polish and wax. If the hair dryer does not give enough heat to to melt the glue then I would go with a heat gun VERY CAREFULLY - try not to melt your paint - take it in short heat applications. Let it get too hot and you will melt/damage your paint.
  3. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    Ok, thanks. I'll give that a try and report back on results.
  4. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Had the same issue with my TR left it out in the sun for a couple of hours grabbed the edge and they came right off used Goofoff and it was perfect good luck
  5. BigTex
    79,397
    Houston, Texas
    Bubba
    I'd agree some gentle heat should loosen them....or find a local thug teenager to rip them off! LOL!
  6. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    apply goop ( avail at home depot) and then work dental floss ( the gentle covered type) slowly back/forth under an edge
  7. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    the 3m is great also alcohol works also peel up the top edge a little or dribble it down from the top as it peels away add more fluid and they should come right off.
    Also real Ferrari's (race cars) have stickers you could buy a set of the magnetic ones then remove or keep on at will?
  8. f355spider
    f355spider F1 World Champ
    18,053
    Another useful way to remove is to use waxed, dental floss. Cut a long section, and tie a couple knots in it, to use as "teeth" to "saw" through the adhesive...start at a corner and work your way through it. Not a fast process, and you will use several pieces of floss to do this, but it is pretty gentle, and can be safer than trying to peel it up. Then use the 3M adhesive remover, or WD40 or Goo Gone.
    These are (IMO) the nicest shields to get: http://www.yomagic.com/ Thin, and accurate to the factory ones.
  9. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Exactly how are these aftermarket logos not illegal under trademark law?
  10. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    This is a good idea - call FNA and tell them you have some illegal shields you want removed. Let them do the work.
  11. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    I have a pair that I've never used on a car but are now on my work bench and the back protective paper said: "officially licensed Ferrari product" or something similar. Even Ferrari dealers sell them.
  12. RMDC
    RMDC Formula 3
    May 15, 2005
    1,005
    Boston, North Shore
    How did you make out? Personally I hae removed Dealer applied signs many times using the process I recommended -
    This was after specifying that I did not want their logo on my car.
  13. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    I have not gotten to it yet. We were in Vegas this past weekend. We stopped by the Ferrari store at the Wynn. Lots of cool stuff!
  14. f355spider
    18,053
    Never use a heat gun...too much risk of damage. Seen it happen to others.
  15. RMDC
    RMDC Formula 3
    May 15, 2005
    1,005
    Boston, North Shore
    Like I said, VERY CAREFULY - have used a heat gun reluctantly, but successfully,after the hair dryer did not generate enough heat.
  16. Ricambi America
    Sponsor Owner
    You're probably referring to the resin shields (decals/stickers) which are indeed licensed.
  17. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Bert Kanters
    Yes, that is what this thread is about, "Removal of resin shields"! The much nicer metal/cloisonne shields that several sources offer are probably all not licensed.
  18. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    In those situations in the past, I have taken the car back with a copy of the law and made the dealer remove it.
    http://www.mass.gov/legis/laws/mgl/90-7r.5.htm
  19. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #19 Impactco, Jun 20, 2007
    Ok, did the job today. Pic#1 is the resin shield in place. I used a hair dryer to heat the badge for about 30 seconds and it peeled right off without removing the paint. Pic #2 is the adhesive residue. Pic #3 is the stuff I purchased at Pep Boys to remove the residue. I soaked a soft rag and the residue came right off with no paint damage at all. Pic #4 is after the clean up with water and fresh coat of wax. Pic #5 and #6 are before and after. Maybe I'll leave it "correct" for awhile and see how I like it. Thanks for all the feedback guys. Oh, Pic #7 is a perhaps a more suitable place for these ugly shields!
  20. Guy Webster
    Guy Webster Karting
    187
    Pasadena
    Guy Webster
    Great job. Good information.
    Guy Webster
    Pasadena
  21. robertgarven
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    #21 robertgarven, Jun 20, 2007
  22. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    #22 Impactco, Jun 20, 2007
