Remove door sills | FerrariChat
Remove door sills
Discussion in '360/430' started by Charly78, May 24, 2015.
  1. Charly78
    Charly78 Karting
    Jan 24, 2009
    80
    France
    Hi
    I would like to change my door sills with carbon sill.
    Is there anybody has removed them ? And how ?
    thank you !
  2. autowerks9
    autowerks9 Formula 3
    BANNED Rossa Subscribed
    Sep 1, 2009
    1,161
    North Wales, Pa.
    David S.
    1. With the door open, Lift the rubber gasket off that runs across the threshold of the opening between the inner and outer sill.
    2. You can either remove or just loosen the rear door opening trim ( where the door catch is located.) make reference where the door catch is located. Also, make reference as to where the sill is located and overlapped by the rear door opening trim.
    3. The door sill should pull loose from the inner seam out. There is some adhesive in the area where it wraps over onto the rocker area.
    4. Clean area underneath sill and install new sill.
    If you have yet to purchase a set we have several different versions available.
    David
  3. Charly78
    Charly78 Karting
    Jan 24, 2009
    80
    France
    Thank you David for your explanation.
  4. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
