Remove F12 rear Cavallino Rampante badge | FerrariChat
Discussion in 'F12/812' started by Gullwing, Sep 1, 2018.
  1. Gullwing
    Gullwing Karting
    Aug 30, 2016
    246
    How do I remove the rear cavallino rampante badge on a F12? I’m trying to do some polishing on the rear and it the badge needs removing. Is it stuck on or bolted?
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Bolted by 3 bolts I believe.
  3. Gullwing
    Gullwing Karting
    Aug 30, 2016
    246
    How do you remove them? Is it via the boot or do you have to remove the whole back panel?
  4. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,560
    Longmeadow, MA
    Eric
    I just had mine powdercoated (Lusso)....the rear panal in the boot had to be removed to access the bolts.....my guy said it was pretty straight forward......
  5. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    Not sure on the F12, But on the Lusso you access it via the boot as per the previous comment. The cavallino is on the boot door though, while it’s on the rear panel on the F12 so not sure we can compare.
