Remove Parking Brake Caliper | FerrariChat
Discussion in '360/430' started by nmercier, Mar 24, 2012.
  1. nmercier
    nmercier Rookie
    Sep 25, 2010
    48
    New Hampshire
    N. Mercier
    I am trying to figure out how to remove the parking brake caliper. I see that there are (2) allen head bolts that attach to the upright on the back side. (1) of the allen head bolts is very tight up against the suspension arm and I am not sure how to get to it.
    Please advise.
  2. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    You need to loosen up the suspension link that looks like a tie rod end. This will allow the clearance required
  3. THINKFAST
    THINKFAST Karting
    Jan 13, 2011
    195
    Earth, mostly ...
    There is a great write-up with photos by Curt, vrsurgeon. This can be found under the Technical Q&A . It is listed as "replacing rear rotors on a 360" Photos showing what he did. Part of the procedure includes removing the parking brake caliper,lots of good info there. Hope it helps...
  4. nmercier
    nmercier Rookie
    Sep 25, 2010
    48
    New Hampshire
    N. Mercier
    Thank you guys very much. I appreciate the information
  5. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Depending on the state; would you still pass inspection???
  6. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Remove the Toe link from the chassis, 2 allen bolts and a 13mm bolt, once removed, the wheel hub swings free. Then remove the 2 allen bolts supporting the caliper to the mounting bracket.
    If replacing the tiny useless pads, remember to rotate the piston clockwise with a set of long pliers, so the piston goes in, due to the new brake pads are thicker.
    Use the proper torque, not over-torque any of the 5 bolts.
