Remove Water Pump | FerrariChat
Remove Water Pump
Discussion in '308/328' started by skipgt4, Aug 22, 2017.
  1. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    I am going to replace the water pump on my ’78 308GTS. All of the step-by-steps that I found show how to pull the whole pump assembly including the thermostat housing off as one unit. Is there a reason to do this if you just want to replace the pump? Can’t you just pull the 7 or so nuts and bolts and remove the pump and leave the housing in place?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    Technically yes, although sometimes they are so corroded that they pump is frozen on and it is easier to work on the whole assembly on your bench.
  3. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    #3 Irishman, Aug 22, 2017
    Well, where you live, I don't know how you will buy me a beer but maybe our paths will cross. :):)
    I have a '78 and have done this job. My write up based on my work and another F-Chat member posts.
  4. dave80gtsi
    dave80gtsi Formula 3
    1,920
    Ohio
    Dave Meredith
    #4 dave80gtsi, Aug 22, 2017
    Yup, just did exactly this, last weekend.
    Behold:
  5. dave80gtsi
    1,920
    Ohio
    Dave Meredith
    #5 dave80gtsi, Aug 22, 2017
    Between the thermostat housing and the face of the block is an o-ring seal. If you do not remove the housing, then you obviously cannot replace this ring.
    In my case the ring was almost new ( ... long story) and I was comfortable not changing it again. But if your ring seal is old, it makes sense to replace it.
  6. skipgt4
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    OK that makes sense. So now about the O ring, is it a generic I can pick up at NAPA or something special I am going to have to send away for?
  7. dave80gtsi
    1,920
    Ohio
    Dave Meredith
    Why not just take your old o-ring to your local auto parts store and match it up?
  8. skipgt4
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    thanks. I will give it a try.
