Removed door panel, found this... | FerrariChat
Discussion in '308/328' started by SoCal308GTSiQV, Oct 12, 2009.
  1. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    #1 SoCal308GTSiQV, Oct 12, 2009
    OK, please look at the pictures below and tell me that the black box with the Fiat sticker is.
    Basically, the cable that connects to the outside door handle broke, so I had to go inside to replace it. After replacing the cable I fit all the parts back in place but when it came time to checking the lock mechanism, the out side key lock wouldn’t work. While looking closer I realized that the black box with the Fiat sticker in question was causing an issue.
    Possibly some sort of an adjustment, although there isn’t much of an adjustment that can be made.
    The interesting feature about this black box is it has wires going to it????
    Is it part of an alarm system?
    Is it possibly part of some sort of power door lock system?
    Is it part of a remote keyless entry system?
    It seems to have some sort of cam mechanism in it that requires the door latch / door lock to travel a certain distance and then it will engage. But because there is no adjustment (that I could find) if the key lock doesn’t travel far enough, this black box pushes the whole assembly backwards with the help of a spring that is in there and the door will not remain locked. However it will lock if you use the inside lock pull.
    All thoughts are welcome.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    SECOND LAW OF NON-FUNCTIONAL APPARATUS
    "All Italian Sports Cars, regardless of age, shall have at least one
    system or component which does not work, and cannot be repaired. Such
    a part shall never be mentioned in the Official Shop Manual, although
    there may be an out-of-focus picture shown." It goes without saying
    that such parts should never under any circumstances be removed, lest
    the natural balance of the car be upset.
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Fiat Whitehead is the torpedo factory on the Med near Pisa. It that thing ticking?
  4. SoCal308GTSiQV
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    LOL, thankfully I left it on the car!
  5. SoCal308GTSiQV
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    It wasn't ticking, but it had a strange hum! (joking)
  6. Llenroc
    Llenroc F1 Veteran
    5,499
    Colorado
    Vern
    It looks like a power door lock system or maybe an alarm system
  7. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Looks like a door lock solenoid.
  8. SoCal308GTSiQV
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    Both things I was thinking, but there is no "Door Lock" switch in the car, and I don't think I have an alarm. Plus, from the look of the wiring, it's factory, not after market.
    Did these cars ever have factory alarms / door locks?
  9. Llenroc
    Llenroc F1 Veteran
    5,499
    Colorado
    Vern
    I was not aware they had either one of those but, from looking at your picture that is what it looks like. Do you have a parts book to refer to and also is your car a Euro version?
  10. SoCal308GTSiQV
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    The car is an 83 US version 308. I don't have a parts book.
  11. britalian
    britalian Karting
    Feb 10, 2006
    64
    Atlanta
    LL
    This is a switch to activate the power door lock in the passenger door. Around 1981 Ferrari added central or curb side locking to the 308. When you lock or unlock the drivers door the passenger door would follow. The drivers side was not power actuated. This is just the switch that tells the passenger door to lock or unlock. Most of the actuators in passenger doors failed early on and many non original owners never knew the system was there. A service bulletin around 84 details the discontinuation of the Fiat boxes for more modern actuators. From that point on there were actuators in the drivers and passenger doors.
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
  13. thecarreaper
    thecarreaper F1 World Champ
    18,077
    Savannah
    my 308 GTB QV has the power lock feature, and it still works! :cool:
  14. DGS
    DGS Seven Time F1 World Champ
    72,128
    MidTN
    DGS
    Ah, interesting.
    My 328 has the double side electric locking. No interior switch: each door follows the other.
    Adjustments can be finicky. For a while, the car used to unlock itself shortly after being locked with the key. (With just enough delay that you'd think it was locked.) If I'd push on the pass side door, it would stay locked. Locking with the button wasn't a problem. I had the shop adjust the linkages, and it's been okay since. (So far.)
  15. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    I added keyless remote to my 328 central locking,,,,I think the locks are located too low to be fumbling around with keys,,,,,,I'll probably take the keyless control box out if I track the car to save on weight :D
  16. Tony K
    Tony K Formula 3
    Jun 7, 2006
    1,779
    Tony K.
    Well played! :)
  17. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    I found the same thing on my car. Only on the driver's side. Ended up installing a new set of SPAL solenoids. Hey, they're Italian!!!!!! Fingers crossed the beloved ghost of St. Enzo approves.
  18. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    #18 flyngti, Oct 12, 2009
    Reading the title of the thread, I had a deja vu. No, I didn't find a door lock solenoid, but something much more puzzling. My door panels were already off when I got the car. I was poking around in there and saw something unusual. There were traces of what looked like a plastic bag that was zip tied to the inner door frame. The bag contained something with wires sticking out of it. After I got it out, I discovered that it was someone's poor attempt at setting up component speakers in the door. It looks like someone dismantled a home component speaker and pulled out the crossover circuitry. They wired this crossover to separate high/mid/low speakers, put the device in a plastic bag to "seal out the elements" then hung it inside the door.
    Crazy stuff.
  19. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    My USA QV came from the factory so that if you lock the driver door by pushing down on the knob, the passenger side will lock automatically. It does something similar when unlocking with the key from the outside... unlock one door, the other unlocks automatically.
  20. SonomaRik
    SonomaRik F1 Veteran
    #20 SonomaRik, Oct 12, 2009
    LOL, taking that out added 5 MPH
    found this in my Mondial T, yup, BMW, mirror controls...probably costs the same as a Ferrari part though...can't win either way.
  21. miketuason
    Feb 24, 2006
    15,814
    Cerritos, CA.
    #21 miketuason, Oct 12, 2009
