REMOVING 308 ENG LINERS | FerrariChat
Discussion in 'Technical Q&A' started by rizzo308, Jul 3, 2008.
  1. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    my engine guy wants to pop the liners out fit new seals .... felt a little bit dizzy wen he said that i dont no if i wanna be heading down that path (can of worms and all that sh#t) there was no leaking issues the water jackets look in great shape no corrosion down there he suggested while the engines stripped why not who has tackled this job .... how bigger job is it .... how hard are they to remove.... if we go ahead what prob are we likely to run into.... cheers
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,630
    San Carlos, CA
    Mitchell Le
    It's just $500 of labor.
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,334
    Edwardo
    #3 350HPMondial, Jul 3, 2008
  4. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    i have made up a puller same as yours .... my engine guy has never done ferr/liners before do they need dry ice to refit them or can they just press them in ............. cheers
  5. 350HPMondial
    5,334
    Edwardo
    I believe just pop them in your freezer, like 0 degrees F, put the block in the sun........ Then drop in, don't twist them!
    The 308 liners are not as tight as the 400i liners.
    (That's why we have "O" rings.)
    Note: The "O" rings don't come in aftermarket kits!
    Get the Real Ferrari gasket kit from Scott, you will get the "O" rings.
    (PS... I love your F car.)
    Good luck,
    Edwardo
  6. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    Hi Edwardo sounds like you have done a few liners.... once new seals are fitted do you bother to get the block pressure tested or once the liners are in theres no way they will leak ............. ps i love my F car to cheers
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,767
    The twilight zone
    Did you get tired of waiting for me to FINAL find the time to box my up and just make your own????
    Sorry :(
  8. 350HPMondial
    5,334
    Edwardo
    #8 350HPMondial, Jul 3, 2008
    Cheers back at you.
    Yes, my shop is going to pressure test the liners. But only to 1.0 Bar
    (And, yes, ha ha, I was in Liner Hell, like you now...... BTW,Ferrari Owners are freakin nutz....!
    Who else loves their cars this much?)
    Everybody keeps telling me to drop in a Northstar V8 and be done. NOT!
    Ciao Bella,
    Edwardo
    Mark,
    No worries mate.
    You are really busy with the babies, so my buddie whipped me up a Hocky puck in 10 minutes.
    Check out my SS weld,,,, huh?
    I'm getting better.
    Cheers,
    edwardo
  9. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    unchartered waters for me .... i 'm having sleepless nights... if the liners are good and they don't leak why am i pulling them just to put new seals in there... what happens when i fit the new seals and they leak maybe i just rebore it and then press test it what do you reckon edwardo ....... cheers mate
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    You have the motor apart. Youve pulled the heads off, and possibly disturbed a liner seal. Getting the liners out takes minutes, shouldnt take more than 20 minutes for the whole deal. If you dont clean down there and put in new seals, your risking a leak, and only a total tear down will fix it. So do you take the risk, after going through all this work, or spend 20 minutes and do the job correctly?
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #11 Verell, Jul 4, 2008
    Also, there tends to be corrosion built up on & around the liners, reducing coolant circulation. With the cylinders out, it can be readily removed. IIRC, Paul Colberg posted some classic pix of the amazing amount of corrosion he found in an engine, one cylinder had almost no water circulation on one side!
  12. rizzo308
    rizzo308 F1 Rookie
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    i removed the liners today all looks good no corrosion what so ever..... todays job clean down block then liners all go's well liners will go back in tu/wens.......... thanks for the advise guys
  13. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Excellent news Rizzo!
  14. Pete Wall
    Pete Wall Formula Junior
    Apr 1, 2005
    361
    Perth, Australia
    Good to hear, mate. Hope you're back on the road soon. Ciao, Pete
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    It wasnt me, both my engines came apart easily, even my heads lifted off without fuss.
