Removing 308 instrument panel | FerrariChat
Discussion in '308/328' started by 63acornwall, Oct 12, 2016.
  1. 63acornwall
    63acornwall Rookie
    Sep 8, 2015
    35
    Hi , I am removing the instrument panel to replace the instrument lights with LEDs.
    I am following the write up by Antonio Regidor , which looks like an excellent guide.
    I have removed the steering wheel and persuaded the four indicator lights to come out in order to reach the screws behind them that hold the panel in .
    Question - as the 4 lights only seem to have a limited amount of free cable , do I have to disconnect them before trying to remove the panel ? Otherwise it looks like the panel will not be very accessible if it is restrained by the light cables.
    TIA
  2. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    Yes Tia - remove the lights to get the panel out. When putting the panel back I put a piece of string on each socket and thread through the panel holes so I can pull the light connectors back out.
    Art
  3. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    The wires are actually connected to the instruments on the panel itself. There is enough cable length between the instruments and where it goes into the top of the dash to pull the instrument panel out and disconnect it.
    Remove the screws and the whole panel will slide out. If the screws fall down behind the panel you can retrieve them when you get the panel out.
    The best way to get the screws back in, is to tape them to the screw driver used to install them until you get them started. Its a hassle if you drop the last one and have to take it apart again to retrieve it. A couple of the screws were slotted not phillips and I replaced them with phillips head ones to make them easier to reinstall.
    All of this will make more sense once you pull out the panel.
    There are connectors to allow you to take the whole panel to a bench to do the upgrade.
  4. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    I would also add if you paint the tabs yellow it makes it easier to find the holes for the screws.
  5. dflett
    dflett Formula 3
    1,632
    NY
    David
  6. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    HI
    Do you have the link to the panel removal? I can't seem to find it?
  7. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    #7 ME308, Oct 13, 2016
    this !
    no need to disconnect them (if you do, mark them for later ...)
    I even changed all my gauges without disconnecting those lights ;)
  8. 63acornwall
    63acornwall Rookie
    Sep 8, 2015
    35
    Well , a quick update . Someone had been in there before and wrapped tape around 2 of the bulb holders which made them a tight fit to remove . Managed to wiggle them out but got sore fingers . I think RHD cars are wired a bit different so you don't get a lot of clearance on the panel when you remove it .
    Managed to drop all 4 screws into the front , retrieved 3 of them , on the hunt for the last one but it will be under the wiring loom . Will use a magnet probe .
    I started this because the panel lights were so dim.
    Turns out that they are not coming on at all now I can see close up .
    So will do some more digging tomorrow . No point in putting new and brighter LEDs in until have power to the bulb holder .
    Question - assume if you pull a bulb holder out from its instrument it will not work unless it is grounded ? Only one wire goes to bulb holder so assume that should be live.
  9. mwr4440
    57,988
    Bavaria, The 'Other' Germany
    Mark W.R.
    Yes.
    I spent about 2 weekends looking for a screw that fell and disappeared into the wiring rat's nest in there.
  10. 63acornwall
    63acornwall Rookie
    Sep 8, 2015
    35
    Ok , made some progress today , managed to recover the missing screw , and have glued back on one of the fixing brackets that broke off as I struggled to remove panel , they appear to be araldited to the inside surface of the instrument panel.
    I fitted 2 XLEDs in speedo , type 74-WHP from superbrightleds.com
    They were easy .
    I fitted 2 X LEDs in tacho , type BA9S-WHP from superbrightleds.com
    They were not so easy as they were slightly too fat for the housing tube . Not by much say 1mm on the diameter , so I filed them down till they fit , you have to remove metal from a ring band and plastic from the bulb cap circumference . When you get down to same size or just below same size as the push-in bulb holder you are there. NB do not twist the assembly as you push it back in otherwise the bulb parts company with the bulb holder and remains stuck in the housing tube.
    Finally short circuited the panel lighting rheostat with a connecting loop. Tried testing the rheostat to measure the resistance but failed to make sense of the readings . It looked fine !
  11. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
  12. dflett
    dflett Formula 3
    1,632
    NY
    David
    #12 dflett, Oct 17, 2016
    The one I bought for the philips screws for my dash was a PH1x125. It was a tight fit around the screw head. Not sure if the PH2 sleeve would be too big.
    The lower screws (if I remember well) were large slotted screws for which I used this:
    https://www.amazon.com/Wiha-40010-Magnetizer-or-Demagnetizer/dp/B00018AONE/ref=sr_1_1?ie=UTF8&qid=1476726090&sr=8-1&keywords=wiha+magnetizer
