removing 328 rearview mirror | FerrariChat
Discussion in '308/328' started by bertrand328, Sep 27, 2024.
  1. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,620
    France
    Bertrand
    Dear all,
    my rearview mirror case look bad and I would like to have it repainted. So i need to remove it, but how to do.
    I tried today but it still on the car and I'm afraid to make a mitake now. Can some tell me how remove the bracket please ? I still don't understand how to do ???
  2. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    211
    CT
    Anthony V Rapuano, Jr.
    The front hole without the wires looks like it has a mounting screw recessed there. That hole gets covered by the rubber bellows of the mirror stalk. The back part of the mirror mount has a plastic cover over it that you can pry off to reveal another mounting screw. Remove the screws, unplug the wiring, and you should have the mirror off in no time.
  3. bertrand328
    Jun 1, 2015
    1,620
    France
    Bertrand
    Thanks Anthony,
    I remove the screw from the front hole but I don't understand how remove the plastic cover to reach the other screw
  4. Anthony Rapuano
    Aug 16, 2022
    211
    CT
    Use a thin blade screwdriver, knife blade, or something similar. Slip the blade under the edge of the plastic cover and pry it off. Try prying gently along the entire edge of the cover versus just in one place. Just be careful not to crack it if it is a brittle, aged plastic. Believe those plastic covers are very hard to find on their own should you need to replace it. Not sure if the cover is being reproduced by Unobtanium Supply.
  5. bertrand328
    Jun 1, 2015
    1,620
    France
    Bertrand
    That is what I would like to have confirmation and not destroy any part
  6. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    Couldn't it just be some kind of hook instead of a screw?
  7. bertrand328
    Jun 1, 2015
    1,620
    France
    Bertrand
    Actually you need to slip a small screwdriver under the edge of the plastic cover and pry it off like as Anthony suggested .. I was not 100% sure that this plastic cover is separate from the rest. Very easy to do in fact !
    Thanks all
