Removing 328 steering wheel | FerrariChat
Discussion in 'Technical Q&A' started by Chiaro_Slag, Dec 16, 2003.
  1. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    #1 Chiaro_Slag, Dec 16, 2003
    My horn wire got pinched & broke off, so I need to remove the steering wheel to fix.
    Anyone know of the tool to remove the funky nut under the horn? I found this on http://tools.baumtools.com/, but they want $81.44 for it - Seems a little steep for a socket! Tool # FR105
    Does anyone know of a better low cost solution?
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Well, I don't have a 328, but here are a couple shots from my 308
  3. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    The wheel comes off by removing the allen head bolts.
  4. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I hope this helps...
  5. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    other side
  6. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    #6 Chiaro_Slag, Dec 16, 2003
    Thanks Dave - I like the instruction manual!
    The allen head bolts are not the problem, I got the steering wheel off ok - I should have been more specific - Under the horn, is a strange nut - I tried to indentify it using your pic of the manual :
  7. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    That is the wheel spacer, and should come off after the allen head bolts are removed.
  8. Steve Magnusson
    24,615
    You'll need to fabricate or buy a ring nut socket to get the hub off (I bought that Baum one myself). Do a search on "ring nut socket" at the old FChat site if you want to invest your time rather than money in a solution ;)
  9. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    Thanks - True, mine doesn't come off after just removing the allen bolts - I need another tool, thanks - I'll start searching.
  10. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    #10 Chiaro_Slag, Dec 16, 2003
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    A tip: The regular Baum tool is such a tight fit inside the colum that it cuts the horn wire (ask me how I know). To avoid this, double the horn wire over & stuff the contact & wire back down inside the groove where it comes up past the ring nut. The wire has to be all the way into the groove. After re-installing the ring nut you'll have to fish the wire out again. (Try tieing a length of dental floss to the bent end of the wire, It's strong enough to fish the wire out with, & thin enough that it won't get cut.)
    If I ever have to pull the ring nut again, I'm going to chuck the ring nut tool in my lathe & turn the o.d down by 2-3mm & also bevel the edge.
    Don't know how tightly Carmen's home made 'Home Depot' tool fits into the shaft, but suspect it's not got this problem. The tool is only about the the diameter of the ring nut:
    http://www.ferrarichat.com/discus/messages/256120/251088.html
