Removing 328 tail lights | FerrariChat
Discussion in 'Technical Q&A' started by Iain, Nov 25, 2007.
  1. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    The tail light lenses on my 328 look a bit grubby inside so I'd like to remove them for cleaning. Had a quick look & they seem to be held on by 3 very small nuts on each lense threaded onto inordinately long studs attached to the lense.
    Is removal as simple as undoing these nuts & disconnecting the electrics? Secondly, any tips on what tool to use to get to the nuts? The studs are so long I'm not even sure a long reach socket will do it.
  2. f355spider
    f355spider F1 World Champ
    18,055
    Be very careful, with age, the threaded metal studs can easily break free of the lens if over tightened. So re-installation must be done very carefully. I might even put a drop of oil or anti-seize lubricant on each stud (threads) before re-installing.
  3. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    I used a deep socket and a socket extension where I could. Just takes time but I got them out just fine. Putting them back in took longer than anything because it was tough to get the nut started on some of the post.
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Thanks, do you happen to remember what size the socket was? I don't own one suitable so I'll need to go & buy it & it would help to know the size. Also, before I actually get in & remove these, can you actually get into the lense properly to clean it from the inside or is it some kind of sealed unit thing? I read something to the effect that it was. (i.e. is it actually a waste of time trying to do this!?)
    rgds
    Iain
  5. FLVICE
    FLVICE Formula Junior
    922
    Ft. Lauderdale
    Edward
    I used a 7mm deep socket on my 85 308 QV Euro
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,663
    Toronto / SoCal
    Rob C.
    The dirtyness of the lens comes from the outside and not the inside. As a whole the inside of these lights remain quite clean. With that said allow me to offer some advice from experience that will help you along:
    1. Do remove all 4 rear lights. You will find that it will make detailing the area around the lights very easy and help you clean the light housings. From memory the nuts holding the lights in place are 7mm and you will require a deep socket to access them.
    2. The coloured portion of the lights is bonded to the black base and cannot be removed without a lot of ungluing work. Thankfully there is no need for this. With the right tricks cleaning the lens on the inside is easy. With the light in your hand and the bulb removed, pour some bleach into the light and some plain uncooked rice. Cover the bulb opening with a rubber gloved hand and shake the light. The rice does an excellent job of scrubbing the light where your fingers can reach. I have used this trick on a number of narrow opening containers and the results are always spectacular.
    3. With the inside of the light now clean you can concentrate on the outside. Chances are if your lights are dark this cannot be saved to much. Over time with exhaust soot these lights permanently stain. The plastic actually absorbs the soot and all the cleaning in the world will not bring them back. That said, some basic cleaning and polishing does go a long way to making the lights look better than if left alone.
    4. With the lights out, be sure to clean and wax the area on the body that they bolt to. This will make future maintanance cleaning all the easier. Look for small chips near the thread holes and touch them up with some paint or nail polish to prevent rust.
    Good luck with the project!
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Many thanks indeed
    I.
  8. PoleApart
    PoleApart Formula 3
    Sep 28, 2005
    1,058
    Warsaw, Poland
    P.
    I've used Meguiar's plastic lens polish to great efffect on the tail lights. It also worked wonders on the rear fog lights - these had really picked up a lot of soot/road grime matting over the years. Maybe it's worth trying before disassembling everything.
  9. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    #9 bert308, Nov 27, 2007
  10. jagjet
    jagjet Rookie
    Oct 24, 2007
    31
    Florida
    W.Robert Phelps, III
    #10 jagjet, Nov 27, 2007
    Just finished doing this Mondial Cabriolet. Careful is the operative word when dealing with these bits. Remove the 3 small screws and slide it out. I leave all the wiring behind and if your not sure what goes where take "Digimages" and mark everythings. Take some warm mild soapy water and capture the swill the comes out! you'll be amazed just how dirty it is. I used Plexus aviation windshield cleaner, polish and anti static spray to reveal the jewel like luster to the lenses. If they are really hazy I use 3M Perfect-it Pad glaze to remove scratches and restore shine. It's the same stuff they buff the car out with.The rubber around the base looks good when re-moisturized by Vinylex by Lexol. Re-install with care and don't forget to wax around it all while it's apart!
    Cheers
    PS if you tackle the Fog lamps they are a mine field,it's easy to break the bulb holder and they are hard to find!
    Robert Phelps
    ZFFConsulting
  11. sskyking
    sskyking Rookie
    Jun 5, 2012
    1
    Santa Ana, CA
    Arthur Sandoval
    Thank you all yesterday I had the misfortune of breaking my Amber lens so I know need to replace it and also to find one ...any suggestions?
    many thanks,
    Art
  12. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
  13. RGigante
    RGigante F1 Rookie
    Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    Excelent advice given already.
    Let me just add that my lens, at 22 years, were in fact very dirty inside. I've used the air filter detergent to clean them on the inside. Worked great! :)
    I took the opportunity to also replace all light bulbs with new ones. Much better now!
  14. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Thanks for that - this thread is from 4 1/2 years ago though! :D
    (but I still havn't got round to cleaning the damn things so it is still relevant - it is getting towards the top of the "to-do" list though :) )
