Removing 348 Rotors | FerrariChat
Removing 348 Rotors
Discussion in 'Technical Q&A' started by adsphelan, Dec 15, 2006.
  1. adsphelan
    adsphelan Karting
    Nov 11, 2005
    54
    I replaced my brakes pad today what an easy job. I was going to turn my rotors, but after trying to remove the rotor has stuck I used a dead hammer and still could not get the rotor off. The rotor's were not in that bad of shape so I just replaced the brakes. After braking in the brakes I have more noise than the old pair. Any ideas on getting the rotors off.
    Dale
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Did you remember to remove the two screws that hold the rotor to the hub axle? They also function to sort of hold the wheel in place so that you can thread the lug bolts. If I remember correctly it should take a 12mm wrench to get them to come loose. If you still have those screwed it the rotor won't come off.
    One more thing, if it was the rear rotors make sure the parking break is not engaged.
  3. fatbillybob
    Aug 10, 2002
    29,241
    socal
    spray wd40 in the lug holes and around the center of the rotor a it meets the hub. Heat it up with a propane torch. WD40 wicks in and loosens. Smack with a dead blow hammer. Shold take 2 minutes. Then take to a kragen or pepboys to turn the rotors.
