Removing 355 valve cover | FerrariChat
Discussion in 'Technical Q&A' started by andrewmr, Jun 26, 2008.
  1. andrewmr
    andrewmr Formula Junior
    Jun 7, 2005
    320
    Bucks County, PA.
    Michael
    Ok, what's the trick to get the covers off.....
    I think I have all the nuts and hardware removed... the prior person that had them off last really likes silicon sealant..... Is there some trick to break the seal?
    And when I put it back together what's the recommended approach when it comes to gaskets? Do you put them on dry or is there some sealant that should be used with the gaskets?
  2. Testa
    Testa Karting
    Mar 28, 2004
    50
    We removed the covers on my 355 engine by using a screw driver. Put it between the cover and the head but be carefull not to damage the aluminium. Using some force the cover will come off. To reinstall it we used the gaskets (attention: there are also 4 small o-rings inside for the spark plugs) and also added the white silicone.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    What I did on my 348 was to remove the rear cam seal covers, or rear cam sensor. Then pop them off by using the space from the hole to get ahold of the cover. It should be the same deal for the 355.
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I had trouble with this too...took some very careful prying to get it to move. I used a screwdriver that I ground down to a very thin leading edge to get in there without damaging the aluminum. I'll let you know in a few months if it leaks :D
  5. andrewmr
    Jun 7, 2005
    320
    Bucks County, PA.
    Michael
    Thanks guys... that did the trick. I have the covers off and it appears that one of them was cracked in teh two lower corners and the repair has started to leak.
    Does anyone have an extra 1-4 cover they would be willing to part with...
    Or know someone that can repair a cracked one.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Probably repairable.
    Pictures?
  7. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    I would think a good welder could fix it up..
  8. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    Hehehe. Are you doing a year-long maintenance or something!?
