Removing 355 water hose | FerrariChat
Discussion in '348/355' started by lotusk, Mar 15, 2016.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Removed the coolant hose connecting thermostat housing to the radiator connecting pipe on the bulkhead.
    When refitting the new hose do i need to bleed the coolant system somehow?
  2. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    When you removed the thermostat housing, did you not notice the bleed bolt on top of it? Thats the "somehow" ;)
    A 10 mil socket is needed I believe, its quick and simple.
  3. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Didn't remove the housing only the hose.
    Yes i noticed the brass bolt.
  4. k17har
    k17har Karting
    Sep 3, 2009
    144
    london, uk
    kayer
    Hi lotusk,Where abouts in London are you ?
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Sorry
    I've moved to southern europe
  6. Jok
    Jok Rookie
    Apr 22, 2013
    10
    any pics of the brass bolt?
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    I'm not gonna bother with bleeding the system.
    The 355 has 2 hoses that run into the coolant tank which self bleed the system....so i've read anyways...
    Just hoping the new hose will not drip at the thermostat housing connection...the thick silicone hose one did and I could not stop it.
    Got to fit the hose by lying on my belly on top of the engine with the steering fluid tank pushed out of the way...not nice!
  8. Jackie and bill
    Nov 29, 2014
    795
    GB
    William
    Why not just do the job correctly while you are there? It will take literally a few minutes to do. The bleed bolt is there for a reason, it's simple.
    Why ask the original question if you had no intention to do so?
    Your next posted question will be, my cars temprature has raised should I ignore it or check my tyre pressures? :D
  9. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, your point is well taken but given he did not drain the system and only removed one hose, is it really required to bleed in this case? Do you think he introduced any substantial amount of air into the system?
  10. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    It's ok MCJoe ....jack and billie don't like me
    They aim sarcasm at most of my posts
    They think we're all experienced mechanics.
    I've only owned a socket set for 18 months...I don't know what i'm doing...this angers some folk.
    I don't even know when to open the bleed bolt if I even wanted to...
    Is it opened with motor running and fans switched on for instance?
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    There are two little hoses, one attached to the bottom of the thermostat housing, and the other attached to the cross-over pipe for the 2 radiators. Their purpose is to allow air to flow up to the coolant over flow tank.
    You simply turn the car on, leave the coolant cap off, run it until it is hot, top it up, and close the cap.
    There is no need for a bleed procedure.
  12. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Excellent info here.
    I never would have known this procedure if I hadn't of asked.
    Now I know and we all know the easy method of a quick coolant bleed on a 355.
    Certainly saves stretching across a hot engine trying to open and close a small essentially hidden screw as others suggested.
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Ias Mitchell already said i also did not bleed when i did my engine out and just. Idled for a while topped up a few times. Also the over fflow is full when it is only about an inch from the bottom, which is about 3 inches from the top. This is the cold level. Do a search i think i have given yo pretty close numbers though.
    Good luck
  14. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanks Grant
