Removing 360 steering column cover | FerrariChat
Discussion in '360/430' started by Dr.Gee, Jul 14, 2018.
  1. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    found an old thread on this that really didn’t clarify removal. Need to remove the shroud to de-sticky. Found 2 phillips underneath. Removing them loosens the top and bottom,but they remain together. Top shell also has an air bag plaque that make me nervous about deploying it during removal.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    The airbag is in the steering wheel - you won't deploy it.
    The upper and lower shell are held together by tabs on each side. You need to separate those.
  3. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    It’s a ***** of a job. You also have to remove a bolt under the steering column to drop it and get more clearance. But even then it’s real tight to get it out.
    Hypek9 likes this.
  4. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    As Dave said, just be mindful about the barbed tabs.
    Else, I found it to be rather straightforward.
    Just take your time and it should not be difficult.
    Going back in is a breeze.
  5. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,104
    South Florida
    Greg S
    There is one extra screw.... I forget where but I almost broke when taking off
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If memory serves me right, there are 4 screws. I'll need to look when I'm at the shop.
  7. irix
    irix Karting
    Aug 28, 2015
    51
    Germany
    J.B
    I have replace my sticky wheel cover against a carbon part some month ago. Having a 360 F1 i have to remove 5 screws in total. 3 are holding the lower unit and tight it against the steering column/shifting unit and 2 more tight the upper unit with the lower together. Additional plastics clips on the left/right of the 2 shells.
    IIRC one of the Macarbon, Remove Sticky .... Companys have a short instruction manual which helps me alot. You need to adjust the steering around to get access to the screws!
    I dont have to remove my steering and i havent touch the airbag for this job.
    Regard,
    Joerg
  8. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Thanks all.
  9. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    Have a link to the video,I couldn’t find it.
  10. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    477
    Buffalo NY
    Jason
    IRRC There are actually 5 screws (2 front and 2 rear plus one at the very back and center) plus a tab on the left and right. There is a strap that limits the column tilt function that needs to be loosened in order to allow the column to drop far enough to get the top cover off, the strap is a solid bar of aluminum on the drivers side of the column with two 8mm bolts, remove the front and loosen the rear. I also loosened the bolts for the lower leather dash trim to allow that to drop a bit further for more clearance but it may be possible without that step. My cluster was not removed. My car is a manual. Hope this helps. Jay.
    Dr.Gee and Dave rocks like this.
  11. irix
    irix Karting
    Aug 28, 2015
    51
    Germany
    J.B
  12. LorenzoR
    LorenzoR F1 Rookie
    This is the correct way to do it or you take the risk of breaking the posts that the bolts go thru. Aside from the screws at the bottom and the tabs on the side the bolt mentioned should be removed to lower the column for clearance. Theres a thread with pics on here somewhere
  13. Dr.Gee
    Dr.Gee Karting
    Mar 18, 2015
    221
    Detroit
    Gee Monie
    yea be careful about those posts.i broke both.i had the added advantage that a prior owner epoxied these as well as multiple other knobs.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    We repair those posts often. Often they are missing so we have machined blanks on hand to do the repair.
    I'm 360 Canuck likes this.
