Removing 360's Front Shocks | FerrariChat
Discussion in 'Technical Q&A' started by THonda, Nov 27, 2004.
  1. THonda
    THonda Formula Junior
    Jul 7, 2004
    724
    Long Island, NY
    TH
    Trying to remove the 360's Front shock in order to raise the ride height.
    Here is what I did:
    Removed the two bolts on top holding the shock & the wire harness
    Removed the lower bolt securing the shock to the sway bar
    Removed the two bolts that holds the sway bar in place
    I ran into a problem of not being able to pull out the rod attached to the sway in order to free the shock. I couldn't push the sway bar anymore as it was against somekind of hose.
    There seemed to be a 17mm/19mm nut at that rod, was I suppose to remove that.
    Any help would be great.
