Removing 456gta rear bumper | FerrariChat
Discussion in '456/550/575' started by Ros456GTA, Mar 8, 2020.
  1. Ros456GTA
    Ros456GTA Karting
    Dec 16, 2019
    68
    Ros Tagard
    can anyone explain how to access the upper 4 nuts holding bumper on.
    they seem to be hidden behind the truck floor.
    manual seems of no help.
    jcbam likes this.
  2. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,377
    Discovered the answer....
    the 2 low nuts on each side = easy, you can see them.
    the upper/outer nut is just visible when you stick your head into the space where the muffler(silencer) box was.
    spanner + patience = solved
    Now the mystery of the upper/inner nut.
    • Open the boot
    • remove the cover over the rear lights
    • remove the leather trim along the lower rear edge of boot
    • lift carpet
    • note that the floor of the boot is covered in a 1/4"thick foam
    • now look for the bulge in the floor panel just below the rear light cluster
    • peal back the foam to reveal a rubber grommet sealed in place with some black sealant.
    • remove the grommet to reveal....... the mystery missing nut
    Photos will follow shortly
    franschman, killer58 and Qavion like this.
