Removing air outlet plates on 360 | FerrariChat
Discussion in 'Detailing & Showroom' started by BZagorski, Mar 10, 2017.
  1. BZagorski
    BZagorski Rookie
    Oct 30, 2015
    13
    Ohio
    Ben Zagorski
    Has anyone tried to remove the air outlet plates without taking off the upper dashboard. There is not much room between the windshield and the air outlets. They need to be sent out to clean up the sticky mess. Any help would be appreciated.
  2. Rifledriver
    37,089
    They are attached from the back side.
  3. BZagorski
    BZagorski Rookie
    Oct 30, 2015
    13
    Ohio
    Ben Zagorski
    Thank You for the help!
  4. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    I was able to clean up the stickies on my 360 vents while still in place. While protecting the dash with a towel, I used alcohol and was able to rub off the black goo. It took a lot of paper towels but I was able to get it all off without taking them off ( once off, they're off, as indicated secured from underneath).
    A little patience and you can clean them up
    Sent from my iPad using Tapatalk HD
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Cleaning of the soft touch is totally different than a proper refinish. Trust me, I don't enjoy doing those parts but feel obligated to give it to you straight :)
  6. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,493
    Honolulu
    Kevin
    A good bunch of terry cloth towels works great with a little rubbing alcohol on it. I used masking tape on the window first and even some on my stitches. Then wet the terry cloth towel and wipe one direction and fold towel to clean area and repeat. Not a tough job but you need to be methodical and keep it simple.
    Get a pack of terry rags from costco and wash on super cycle in hot and then dry on hot and then they are ready. The more you use the safer you are being.
  7. Ricambi America
    Sponsor Owner
    On very small pieces (like the clips which conceal dash vents for a 348), you can use Purell hand sanitizer. It will remove the sticky goo, and leave the base black plastic. Whether that resulting black finish is acceptable is everyone's personal choice, but the Purell does dissolve and remove the goo.
    p.s. Ben, thank you for your order yesterday !
  8. Rifledriver
    37,089
    You guys all must have much smaller fingers than I do. Cleaning them in place is something I could not even consider.
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Same as above would not even consider being couped up over seats for hours.
    My guess is I would ruin something else, like sitting on switches, bolsters etc
  10. woody byrd
    woody byrd Formula Junior
    690
    cary, nc
    woody byrd
    Hi Daniel, We have not seen you in quite a while. I hope all is well and you and business are doing fine. Miss not seeing you. Maybe you will come back and join us at some FCA events again sometime. Kind regards,
    Woody
