Removing brown undercoating stuff? | FerrariChat
Discussion in 'Technical Q&A' started by plugzit, Oct 20, 2007.
  1. plugzit
    plugzit F1 Veteran
    7,773
    Redondo Beach, CA
    Bruce Bogart
    Anybody know a good chemical that will melt away the undercoating junk they spray underneath 348s without taking the paint as well? I'm really tired of trying to use lacquer thinner. That junk is sprayed willy-nilly (technical term) into the subframe and looks like crap!
  2. fatbillybob
    Aug 10, 2002
    28,813
    socal
    Hillbillys use a propane torch and a putty knife. Leave a thin coat on these cheapo 4re's rust!
    Even if you spend big $ there is no best way to get the crap off. Sandblasting...you never get all the sand out of the nooks and cranies. Acid dip likewide and the acid will eat the car!
  3. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Try spraying on brake cleaner, it should work. It does dissolve the black undercoating which drips right off, and it won't affect paint; no wiping required.
  4. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Don't use lacquer thinner. That stuff will eat your paint. I use var-sol, a common mineral spirits paint thinner available anywhere. It cleans parts, removes tar and is not flammable like some others. Painted surfaces can be washed down with soap and water after cleaning. Hint. If used for cleaning paint brushes or parts. Decanting into empty wine or liquor bottles allows the paint or dirt to precipitate out and the var-sol can be used again.
  5. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    +1 on the mineral spirits! However still exercise caution as it is flamable but not to the point that lacquer thinner or gas are. To speed up the wash & rinse process use alcohol as it will remove the oily residue left behind from the thinner and quickly evaporates leaving behind a clean surface. And do save that used thinner as described above, it can be used over & over again. It'll take a few days for the paint solids & dirt to settle to the bottom, after that carefully pour off the spirits to a clean container for reuse. It does take on a yellowish tinge when recycling but still very effective.
  6. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    I repeat.....brake cleaner, just spray it on.
  7. ZINGARA 250GTL
    Jun 21, 2002
    17,499
    PA
    Ken
    I'm glad to meet another cheap bastid. I keep separate bottles for parts, varnish, and paint. A Gallon of mineral spirits last me about five years. Thanks for the tip on the alcohol.
  8. Llenroc
    Llenroc F1 Veteran
    5,465
    Colorado
    Vern
    I will help you repeat what works best...Brake cleaner, Spent hours on my 348 a few years back getting that goofy brown sh@t off the under carriage and engine.
  9. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Economical, YES....but also environmentally responsible thing to do.
  10. plugzit
    plugzit F1 Veteran
    7,773
    Redondo Beach, CA
    Bruce Bogart
    It doesn't remove the paint too?
  11. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Removing it will cost you points at an FCA concours...keep it original and enjoy...
  12. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Vintage car magazines here recommend dry ice blasting. Completely removes anything without damaging the actual car parts. Even rubber hoses won't be damaged. Quite pricey, though...
  13. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    ROFL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    plugzit, use Brake Cleaner and it will come right off.
  14. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Nobody listens :-0
    Works for me as well
  15. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    NO!!
  16. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    I know.......I know....! :(
  17. Llenroc
    Llenroc F1 Veteran
    5,465
    Colorado
    Vern
    What? LOL
  18. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    :p :D
  19. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    I thought it was a great idea.
    Only wanted to fill in on the other alternative if that process were needed in some other fashion.
  20. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  21. Llenroc
    Llenroc F1 Veteran
    5,465
    Colorado
    Vern
  22. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
  23. Llenroc
    Llenroc F1 Veteran
    5,465
    Colorado
    Vern
  24. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
  25. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    You are right, not as flammable. Min spirits is actually not a flammable, but a combustible......needs a higher flash point.
