355 - Removing covering under door | FerrariChat
355 Removing covering under door
Discussion in '348/355' started by evo11, Jul 12, 2021.
  1. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Gentlemen,
    to remove the outer covering under the door do I have to remove the rubber with the inscription ferrari?
    if so, would anyone help me choose the number of this rubber element? My guess is that after detaching it will no longer be usable?
    Is it # 14
    62172100 ?
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The rubber is contact cemented into an inset. Removing the rubber wont do anything. The entire sill that the rubber is mounted in needs to be removed.
  3. 05elise
    05elise Karting
    Jul 20, 2011
    211
    Sharpsburg, GA
    Dan
    #3 05elise, Jul 12, 2021
    Yes, that black plate with the rubber logo on it needs to be removed and it is difficult to pry it off the sill due to the adhesive Ferrari used. You need to be extra careful about prying up on it if you intend to reuse it because the panel distorts easily and there is no advantage to be gained by removing the rubber strip from the plate.
  4. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    Thanks guys, it's removed now
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Good man, post the rest of the removal of the lower jamb cover for others. After the door sill is removed, what did you do next? Any pics?
  6. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    #6 evo11, Jul 17, 2021
    Gentlemen, thank you for your help. The car is at car spa, where it is thoroughly cleaned and maintained. The whole car will be covered with transparent foil. During the works, it turned out that the external thresholds have slight gaps of colorless varnish. To remove them this involved unscrewing the upper part of the sill on the cabin side, after removing the rubber parts with the Ferrari inscription
    Pepsi10 and Qavion like this.
  7. evo11
    evo11 Karting
    Sep 21, 2020
    188
    K
    And more
    Mmckee and Pepsi10 like this.
