Removing decklid release latch (77 308GTB) | FerrariChat
Discussion in '308/328' started by decampos, Apr 20, 2009.
  1. decampos
    decampos Formula Junior
    443
    Los Angeles
    Ben
    #1 decampos, Apr 20, 2009
    Does anyone know the best way to remove the plastic housing to the engine lid release latch? I have a feeling the latch and the housing might not separate. If that's the case, what's the best way to remove the whole unit?
    Many thanks.
  2. Mule
    Mule F1 Rookie
    3,750
    Alaska
    Mule
    The metal latch is connected to the cable that releases the rear lid. The metal latch is also attached and pivots inside the black frame. If you lift the latch, you will see a small screw under it that holds it in place. Even if you undo the screw, the latch and frame are held back by the cable which goes back to the deck lid latches.
    Do you want to replace the latch or frame? The chrome and black parts come as one piece from Ferrari, but you may be able to find them seperated somewhere. If so, do a search on broken deck lid cable or those types of terms. Replacing the cable (or at least removing it) goes with the latch.
  3. BigTex
    79,143
    Houston, Texas
    Bubba
    The latch handle is pinned to the cup....correct it's an "assembly" in the parts catalog.
    Unobtainaium Supply makes the replacement bucket and provides a tutorial on it's installation.....
    I'll offer be VERY careful here, as if the engine lid shuts and the latches are not working, you have to smash out tail lights, I'd remove them in advance, if you are going to "adjust" the cabling.....
  4. decampos
    443
    Los Angeles
    Ben
    Thanks for the replies chaps. Nothing's broken, I just need to remove all the trim items along that area to do some restoration work on the paint. Is it not easy to detach the cable from the latch to temporary remove it or is it waaaay to much hassle?
  5. BigTex
    79,143
    Houston, Texas
    Bubba
    No worries, just be aware you'll disarrange all the latch cable adjustments, and don't let it fall back into the recesses of the body work.
    Maybe contact our Verrell and get him to send a .pdf of his instructions???
    They are very good.....
  6. decampos
    443
    Los Angeles
    Ben
    I will do. Thanks. Do you know how the cable is attached the the latch? I can't get enough access to work that out. I can only imagine it would be a nightmare to re-attach.
  7. Mule
    Mule F1 Rookie
    3,750
    Alaska
    Mule
    #7 Mule, Apr 20, 2009
    The cable comes out of the bodywork and has an eye at the end. It goes over a post on the back of the handle and is secured with a nut and washer. I do not think you can get to it without undoing the cable at the latches and pulling the whole thing out. There is one screw that holds the handle to the body, and one nut that holds the cable to the handle.
    To do this you pretty much need to follow the replacement cable procedures that I learned below:
    http://www.ferrarichat.com/forum/showthread.php?t=128924&highlight=mule+cable
