Removing Distributor Caps - Mondial | FerrariChat
Discussion in 'Mondial' started by Vivaldi, Oct 3, 2009.
  1. Vivaldi
    Vivaldi Karting
    Aug 1, 2001
    83
    SoCal
    Alex Vivaldi
    Seems simple enough...while I was waiting for a clutch slave cylinder, decided to replace the ignition wires (since I had to remove the front bank distributor cap to access the slave more readily). Did that one without problem, and figured I was home free. Oh well!!! Can't figure out how to get to the bottom screw on the rear bank distributor cap. Tried a small 8-mm open end and a stubby small screwdriver, but just can't get either tool in the right position. I am sure many of you have done this...so what's the secret? What tool? Access from what angle? With which hand?
  2. moysiuan
    moysiuan F1 Rookie
    4,242
    Canada
    This was a huge problem for me. Through the wheel well, with a small open end wrench that I bent slightly in a vise, I was able to get it tightened. Unbelievable amount of effort, and I think the cork gasket slipped a bit, probably best to put some gasket sealent on the cap and let the gasket set overnight.. I can't bring myself to do this again. Sorry, but I have no real advise, but I thought it was just me that thought this was a tough one. I eagerly await a F mechanic who probably get 10 minutes of shop time allocated to this to share the secret.
  3. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    1/4" drive (I forget which size metric) socket with 2-3" ext and ratchet. All 1/4" drive. Works fine.
  4. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    I took mine off through the front access plate. Just lower the rear seats, remove the access plate and the distributor cap is there.
    It is also much easier to bleed the slave cylinder once you install it.
    Good luck!
  5. FamilyCar
    FamilyCar Formula Junior
    790
    Seattle, Wa
    Peter Goodall
    8mm deep socket on this little wrench.
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94011
    For putting it back on, using an 8mm on an adapter for 3/8 to 1/4" drive was just the right depth to push it on.
    It takes a bit to find the right hand position. I also found that standing on a small platform really helped get the right angle--I built a step about 6" high which is great for leaning over the trunk.
    Loosen all the wires from the looms and push them around a bit, then the socket easily follows the groove in the side of the cap.
    If it makes you feel better, it took me 16 hours to get both caps off the first time, now its about 20 minutes.
  6. Vivaldi
    Vivaldi Karting
    Aug 1, 2001
    83
    SoCal
    Alex Vivaldi
    Thanks everyone and in particular Peter. I have also implemented a step stool (particularly since I have the rear end on jacks for the clutch slave cylinder swap). I have a Harbor Freight within 4 miles of home. Will stop by there right after work and will post outcome for everyone.
  7. 350HPMondial
    350HPMondial F1 Veteran
    5,336
    Edwardo
    Push a 8mm nut driver right through them wires, parting them, guide the driver with the other hand into the groove. Presto
    Edwardo
