News
Removing front shockers from a 550
Discussion in '456/550/575' started by Earl of Cavendish, Mar 17, 2020.
  1. Earl of Cavendish
    May 22, 2013
    24
    Victoria,Australia
    James Earl
    I need to remove both front shock absorbers from a 550 and send them away for repairs,how do I do this ,what tools are needed and the car will be left without suspension for a period of 2-3 weeks is this doable?
  3. ferraridriver
    ferraridriver F1 Rookie
    4,102
    Bay Area Calif.
    Dave
    Shock removal Rear:
    Remove wheel
    Support suspension with a transmission jack or something similar.
    Undo two mount upper nuts (17 mm socket)
    Remove lower nut and bolt (19 mm socket) note washer orientation
    Lower suspension while supporting shock, reach up over shock and release actuator clip, remove actuator leaving actuator connected.
    Remove shock
    Front:
    From top, Remove actuator; undo four nuts on top mount
    From bottom
    Remove under tray
    Turn wheels fully one way, (slowly or power steering fluid will overflow)
    Remove wheel, support suspension
    Remove sway bar bushing brackets, let bar hang down
    Remove shock lower nut and bolt
    Lower suspension and remove shock
    Mirek, white out, Qavion and 2 others like this.
  4. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    562
    Toronto
    Ryan
    I do it a bit differently for the front shock, I'm sure there is more than one way to do it. I don't remove the front undertray, but I guess it depends how you are supporting the vehicle, I use quickjacks. I don't touch the sway bar. I remove the actuator and the 4 13mm bolts on the top of the shock, then remove the bolt through the bottom of the shock connecting it to the lower control arm (19mm I believe), the shock will drop down, but I cannot get it out from in-between the upper and lower control arm, so I disconnect the upper control arm from the upper ball joint (2 13mm bolts), raise the upper control arm out of the way and pull the shock out.
  5. Earl of Cavendish
    May 22, 2013
    24
    Victoria,Australia
    James Earl
    Thanks to those who replied to my request,I found the solution of Avimax the best for my situation and they came out with a little jiggling,they are now about to be sent off for refurbishment.I used 3 jacks ,one in the centre of the 4 post hoist I have this lifts against the cross member under the sump and one on either side (small mechanical bottle jacks) using the front jacking points as I will be leaving the car as is until the parts return.
  6. white out
    white out Formula 3
    1,008
    SoCal
    Nick
    I tried the Avimax method, but had to remove the swaybar from both lower control arms and rotate it out of the way to get enough clearance between the control arms to remove the shock.
    This was on a 575M.
