Removing handbrake console in 355 | FerrariChat
Discussion in '348/355' started by lotusk, Dec 17, 2012.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Hi
    Any special tips to help me remove the handbrake leather console in my 355...
    Seems that the engine lid opening cable is tricky to remove and replace..
    Howard
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    That's the tricky part.
  3. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    It'a a real PITA to remove and putting it back is worse....took me an insane amount of time to clip the handbrake cable back in...
  4. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Any tips then?
    Howard
  5. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Not sure if it can be done but if the mechanism where the lid handle can be left intact (don't think it can...) then you should leave it without dissasembling.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Leave it in. ;) Unless you're replacing it with a new one it's hardly worth the trouble. Cleaning and redyeing the leather can be done "in the car". It's a lot easier to remove the seat.
  8. RSO1091
    RSO1091 Formula 3
    Mar 31, 2012
    1,547
    Idyllwild, CA.
    Henry S.
    +1. I recently had to replace the engine bonnet release cable because mine broke near the handle. I went ahead and cut a slot in the bracket (as suggested before) to allow me to slip the cable back in more easily. Coincidentally, I was replacing a defective, left side radiator at the same time and discovered that you cannot replace the entire release cable without removing the radiator itself. The cable is secured to the body, just behind the ribbed intakes of the rear fender. The only alternative would be to leave the original casing in place and then try to thread the new cable through it. But because the cable takes so many twists and turns and is secured to the infrastructure at so many points, I'm not sure if that would be effective. If you can avoid taking the cable apart, I echo the sentiments expressed before. DON'T DO IT! Good luck either way...
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    It is easier with the seats out of the car so you can work for the inside (the car) position.
    But it is almost a "you can't get there from here" proposition. Tricky and intricate.
    What really pisses you off is when you put it back in and then forgot something and have to do both steps again.
  10. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    That's how I did it, just make sure your slot is only the width of the cable itself!
