removing high tension cord | FerrariChat
Discussion in 'Technical Q&A' started by dersark_painclinic, May 7, 2008.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    I am in the process of replacing the spark plugs on 550 maranello, any body can tell me how the heigh tension cable comes out. it is just pulling straight up by a special tool or it is a screw type. If it comes straight out where can I get the pulling tool. Thanks for any advise.
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,387
    Frederick, Maryland
    Brian Brown
    The spark plug connectors just pull straight off. You just use your fingers, there is no special pulling tool.
  3. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    I tried very hard to pull off, I do not see any sign of becoming lose, the ruber cap is tightly sitted on the valve cover. usually there is a tool to grab the cord to pull off.
  4. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Just keep at it mate. If they have been on there a while, they will be very tight. :):)
    You can use some pliers to pull on them, but you have to be VERY careful not to damage the leads. :):)
    Trust me, they HAVE to come off some way or another. ;);)
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Thanks all
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Push down on one momentarily, then twist it only 1/8th of a turn left then right. Then pull up with your hand (holding the end of the wire, not the wire itself).
