Removing intake compensation cover - 360 | FerrariChat
Discussion in 'Technical Q&A' started by billwilletts, Jul 1, 2025.
  1. billwilletts
    billwilletts Rookie
    Jun 7, 2025
    23
    Kenosha and Myrtle Beach
    William Willetts
    I was going to remove the cover and get it powder coated since it isn't looking too sporty anymore. It is as simple as removing the cover or will have a project on my hand? Looks like there might be a gasket as well?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    What model do you have?
    You just want to remove the red ... top?
  3. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
    If you mean part #4 on diagram below, no gasket and remove only 2 screws among the 4. The 2 other screws are going through the cover without holding it.
  4. RedNeck
    RedNeck F1 World Champ
    12,267
    The CSA
    Me
    If you are talking about the red upper intake manifold, then yes, you will have a small project on your hands. You will need a Chapman set to get to all the screws without going through the access panel inside, There will be 2 gaskets that go in between the upper and lower intake manifold, also a gasket that that goes in between the upper manifold and compensation ducting...and to powdercoat you will also have to remove the flap assembly that will take a bit of skill to put back together correctly.
  5. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    For a Spider it gets much more difficult to do,
  6. billwilletts
    billwilletts Rookie
    Jun 7, 2025
    23
    William Willetts
    360 Spider - the cover in the diagram #4. Is that easy to remove and reinstall?
  7. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    That small #4 plate is quite easy to remove.
    The number 1 intake plenum is much harder to remove, especially for the Spider.
  8. billwilletts
    billwilletts Rookie
    Jun 7, 2025
    23
    William Willetts
    is it hard to know which 2 screws are the right ones so I don't do the wrong ones? From the top they all look the same
  9. eric355
    eric355 Formula 3
    1,225
    Toulouse (France)
    Eric DECOUX
  10. billwilletts
    billwilletts Rookie
    Jun 7, 2025
    23
    William Willetts
    Ahhh... I see now. Thanks a lot for the assist
