Removing Old Coolant 360 | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by alex360S, May 7, 2010.
  1. Skidkid
    Skidkid F1 Veteran
    9,659
    Campbell, CA
    John Zornes
    You would only expect it to run hotter if you were exceeding the capacity of your cooling system. If not, the system would stay at the temp set by the thermostat. Track conditions can put a LOT of extra heat into the system. It can be enough that the cooling system has a hard time keeping up. In those circumstances you would see a lower temp with water wetter than without. You would not see any difference in normal street driving.
  2. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Sorry Mike I miss understood. I agree with you and John over water wetter.
  3. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    I see...now it makes sense because I don't track, pure street driving.
    No worries ;)
  4. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    Using the water wetter will not lower your preset (thermostat) operating temp range, however I did notice a faster heat exchange taking place.
    Basically as the car sat idle the coolant temp would go up, as soon the car starts the move the temp gauge moves down much quicker than prior with just anti-freeze.
