Removing Rear Lid Marker on a 360 | FerrariChat
Discussion in '360/430' started by slice, Sep 15, 2010.
  1. slice
    slice Formula Junior
    Jan 4, 2008
    312
    Connecticut, US
    Apologies in advance if this is covered elsewhere, I've searched and cannot find a photo of the removal of the rear "Ferrari" marker. My shop gave me a few clips and everyone claims it is easy to "pop" them off from underneath, but with what? Also, are those two clips (on a 360 truck lid at least) the only thing holding it on, or am I going to knock said clips off only to find the thing still cemented on? Photos and real life experiences welcome.
    Thank you
  2. viperdrew
    viperdrew Rookie
    May 15, 2010
    9
    NJ
    Drew Geffon
    The Ferreri emblem is affixed from underneath with these two clips, you can actually grab them with a long nose plyers and gently unscrew them. The emblem is also affixed with two sided tape, so it must also be gently worked loose. You can also try using some dental floss to work underneath the emblem from above to loosen the grip of the two sided tape, just watch the screw posts and be careful as the emblem is easily bent.
  3. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    On mine, the clips were pulled out but not screw out so they were basically destroyed in the process of removing. As long as you already got the spare clips (2 at least) then should be ok.
    To put the clips back on, use a small socket with the diameter slightly bigger that the clips to push them up - this will make the job much easier (push up slow and careful NOT TO DROP).
    Very easy job - just have to do it slow.
  4. slice
    Jan 4, 2008
    312
    Connecticut, US
    Thank you for the replies...
    So it does have double sided tape...the next question then is: Will the double sided tape still have some level of "stickyness" left once I remove the marker and try to replace it?
  5. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    If you are careful and lucky enough then you might be able to reuse the double sided tape. Most likely it will be destroyed in the removal process as well.
    You can buy some very thin 3M double sided tape to replace it with.
  6. Kds
    Kds F1 World Champ
    Fishing line also works for removing badges stuck on with 2 sided tape.
