Removing RHD radiator on 348 | FerrariChat
Discussion in '348/355' started by angelis, Aug 6, 2006.
  1. angelis
    angelis F1 Veteran Owner
    Jun 18, 2004
    6,400
    London, England
    Sy
    When removing the RHD radiator, would the oil rad underneath need to come out as well?
    Update on my overheating problem:
    Since buying over £1,000 worth of rads and fans this week (But not installing!!!!), the 348 is no longer overheating. However the oil rad fan has stopped working!!!
    :mad: :mad: :mad: :mad:
    I'm still replacing everything anyway. :)
  2. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    From just looking at it I'm gonna have to say no. But then again I haven't had to pull the right side radiator. I do know that there are two bolts that hold the top radiator to the bottom oil cooler.
    There is a retaining bracket that holds the radiator in place from the top. Two nuts hold the bracket, to a bar, that is up under the rear quarter pannel. You will need to remove the front part of the wheel well liner to get access to the radiator, maybe even the top one too for more room to move. Once you have access remove both of those nuts and then completely take the bracket out of the way. But before you do that, drain the radiator via the plastic screw on the bottom right hand corner, disconnect both of the hoses, and unhook the cooling fan wires. After you have removed the top bracket this should give you some room to lift the radiator up off of the oil cooler, of course after you remove both of the bolts holding it to the cooler.
    Try that before you drain the engine oil and disconnect the oil lines to the cooler.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If you get a little water/coolant on the fan connection you'll sometimes blow a fuse.
    I'd suggest disconnecting the electrical clip on the radiator, applying Stabilant 22a to the contacts, then reconnecting. Replace the blown fuse in the passenger footwell (assuming that's the correct location for UK cars).
  4. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    How do you know it's stopped working?
    It only comes on when the oil gets hot.
    I had to replace my temp. sending unit on the oil radiator as the fan stayed on continuously.
  5. angelis
    Jun 18, 2004
    6,400
    London, England
    Sy
    Thanks for the info guys. Will be doing it this week.
    I checked it when the oil was very hot, about mid point on the dial and the fans was'nt working at all.
    I'm going to replace the fan switch and see if that works. Otehrwise it's a case of trying a new fan.
  6. angelis
    Jun 18, 2004
    6,400
    London, England
    Sy
    Had a look at the manual and it says the following about removing the rads:
    Disconect the two water ducts and the electric cables if working on the right hand radiator (on the left side instead the tank filler must be removed)
    What's the tank filler?
  7. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    The length of pipe that directs the fuel into your fuel tank :D
  8. angelis
    Jun 18, 2004
    6,400
    London, England
    Sy
    Doh!!!
    Thanks :D
  9. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    The manual is whacked. I've changed my left side 348 Spider radiator and you don't have to remove the fuel filler line. Heck, it's just a few bolts and screws to yank the thing out: http://webpages.charter.net/aircover/348/1994Ferrari348Spider.html#Water
